Print Page | Close Window
CA drag link question.
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=14232
Printed Date: 02 Feb 2025 at 5:10pm
Topic: CA drag link question.
Posted By: Larry in OK
Subject: CA drag link question.
Date Posted: 22 Jun 2010 at 6:32pm
I've seen pictures of a few CAs with the drag link to the outside like the one shown below from Charlie175's pics of the Woodstock show Charlie175, if you'd rather I not link to your pic let me know and I'll take it out) I'm thinking this was done to make clearance for the alternator maybe. What would have to be done to do this or is this considered an abomination?
Posted By: GregLawlerMinn
Date Posted: 22 Jun 2010 at 6:43pm
Generally done to provide more clearance (alternator, add-on pump, etc). The arms that the drag link attaches to are tapered bores; one has to ream out a taper from the outside to install the drag link there.
Posted By: Bee
Date Posted: 23 Jun 2010 at 6:32am
nother pic
Bob, North Carolina
1949 B
Posted By: Steve in NJ
Date Posted: 23 Jun 2010 at 4:49pm
The "SI" series Alts can be used as shown, but the SI's cousin, the "CS" series is even more pint size, and will fit even better. The CS needs to be hooked up a little differently, compared to its cousin the SI, but the fit works great! Mounting would basically be the same....
Steve@B&B
Date Posted: 23 Jun 2010 at 10:49pm
Is the mounting different or wiring or both? I'm kind of averse to swapping the drag link to the outside but I'm gonna put an alternator on this thing.
Date Posted: 24 Jun 2010 at 7:15am
Larry
I got a CS alternator setup (wiring harness, mounting bracket, and instructions) from Steve for one of my CA rehabs and it fit just fine W/O reversing the drag link. After having a few electrical shorts from faulty ammeters, I now replace the ammeter with a voltmeter.
