Print Page | Close Window
7000 hydraulic pump
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=139285
Printed Date: 19 Jul 2025 at 10:52am
Topic: 7000 hydraulic pump
Posted By: Tim NH
Subject: 7000 hydraulic pump
Date Posted: 10 Jun 2017 at 8:12pm
I drained all the hydraulic oil from transmission. Put in new filter, and just on the other side, I also took suction line off to put a new donut and steel washer in to stop a leak. When I started the tractor, the high pressure light is on. The lift arms won't come up, and no power steering. So I need help on how to bleed the air out.  Thanks Tim
Posted By: MACK
Date Posted: 10 Jun 2017 at 9:58pm
With someone on tractor holding clutch down, put air pressure in filler hole with engine at 1/2 throttle. Use a rag wrapped around air nozzle to seal filler.     MACK
Posted By: Tim NH
Date Posted: 11 Jun 2017 at 6:05pm
I didn't have good luck w/ my OSHA approved air blowing nozzle. So I made up a gem. Set regulator at 60 lbs. In 2 seconds I heard the 3 pt hitch come up. The steering worked, and the light is off.  Thank you Mack.  Tim
Posted By: Ted J
Date Posted: 12 Jun 2017 at 8:28am
Awful easy fix Tim!
Mack, WHERE do you get these ideas?!?!?
Posted By: MACK
Date Posted: 12 Jun 2017 at 10:13pm
Experience.
