D-15 PTO Lever Repair
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=127374
Printed Date: 04 May 2024 at 12:23am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: D-15 PTO Lever Repair
Posted By: Austin(WI)
Subject: D-15 PTO Lever Repair
Date Posted: 17 Aug 2016 at 8:03am
We lost the detent balls on the PTO lever. We can already see this is going to be fun getting the new ones in. Any tips/tricks to do this? Dad is worried we will have to split the tractor. We already got into the housing via the plate, but it's tight quarters.
------------- "Better By Design"
Posted By: Don(MO)
Date Posted: 17 Aug 2016 at 8:12am
I have replaced the spring, ball or lever from going into the side cover and it's tough but can be done, helps to have two working on it; if it's your first time doing this might save time to just split the tractor. I'd change the O-ring on the PTO lever at this time too.
------------- 3 WD45's with power steering,G,D15 fork lift,D19, W-Speed Patrol, "A" Gleaner with a 330 corn head,"66" combine,roto-baler, and lots of Snap Coupler implements to make them work for their keep.
Posted By: JimIA
Date Posted: 17 Aug 2016 at 8:17am
x2 on the oring. I always sell one to the customer if they have a tractor split and tell them they will thank me when they don't have oil on the platform. Kind of like how I always advise the customer to get new input shaft seals when doing a clutch job.
Jim
------------- An open eye is much more observant than an open mouth
Posted By: DrAllis
Date Posted: 17 Aug 2016 at 8:50am
I'm trying to figure out how the ball (not balls)got lost ??? It can't just fall out out....
Posted By: Allis dave
Date Posted: 17 Aug 2016 at 3:08pm
It was like that when I found it....
Posted By: Dan73
Date Posted: 17 Aug 2016 at 4:45pm
Leave it alone. My d17 had the spring collapsed when I got it so in effect it had no detent ball. I fixed it when I had the torque tube apart and wish I hadn't. We used it for years with no detent and it never gave any trouble. Now it is a pain to get it to pop out of the detent half the time and I can't figure out if the pto doesn't line up or if the ball is sticking. Can't wait for that spring to die again.
Date Posted: 17 Aug 2016 at 5:46pm
Sorry. It is just one ball. I was just basing this off of what Dad was telling me over the phone at first. The pin on the shaft came off and the forks fell off....could not engage PTO. It was all laying in the bottom of the chamber.
Posted By: DiyDave
Date Posted: 17 Aug 2016 at 6:19pm
To paraphrase Garry Lee, Here comes johnny, he's a one balled man, with his lever in his hand...
Caution, explicit lyrics...
https://youtu.be/DKObJ-zHKLc" rel="nofollow - https://youtu.be/DKObJ-zHKLc
Posted By: DrAllis
Date Posted: 17 Aug 2016 at 6:28pm
Replace the pin with a 5/16" bolt about 2 inches long and a locknut. I'm trying to envision getting the ball and spring slipped back together thru that square hole. Definitely want to silicone the ball in the arms hole. Then, a second person has to slide the lever back in the housing while you hold the fork.
Date Posted: 17 Aug 2016 at 6:43pm
Thanks Dr. Allis...we will give it a shot!
Posted By: Don(MO)
Date Posted: 17 Aug 2016 at 7:10pm
Austin(WI) wrote:
Sorry. It is just one ball. I was just basing this off of what Dad was telling me over the phone at first. The pin on the shaft came off and the forks fell off....could not engage PTO. It was all laying in the bottom of the chamber. |
That's what I was thinking but for one time in my life I didn't say it.
Posted By: Don(MO)
Date Posted: 17 Aug 2016 at 7:19pm
I had a early D17 come in with the PTO lever in the tool box with oil leaking down the side of the tractor owner said it just fell out, the pin was gone and the shift bracket the ball ran in was down it the bottom of the housing found the ball in the oil I drained out but I didn't find the pin asked the owner if he had been inside then I got the hole story, he had tried to change the O-ring to stop the oil from leaking out and dropped the bracket when he pulled the PTO leaver out, so I rebuilt a old push rod to hold the ball inside the case as I installed all the pieces back togather, one hell of a job by my-shelf. Two can do it.
Posted By: DrAllis
Date Posted: 17 Aug 2016 at 7:49pm
With the PTO lever in the engaged position, once the pin is removed, one can hold the fork while the other helper rotates and pull out the lever.. reinstall the same way...ball and spring will never get lost.
Posted By: dn29626
Date Posted: 27 May 2022 at 12:04pm
I know this thread is old. https://www.ebay.com/itm/323773062037?hash=item4b6260db95:g:tBgAAOSwUvVcfIYcis" rel="nofollow - https://www.ebay.com/itm/323773062037?hash=item4b6260db95:g:tBgAAOSwUvVcfIYcis Is this image (second pict) showing where the bolt needs to go? I got it from Ebay
