Print Page | Close Window
Tru-Power 4 1/8 complete kit
Category: Other Topics
Forum Name: Pulling Forum
Forum Description: Forum dedicated to Tractor and Garden Pulling
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=121450
Printed Date: 21 Mar 2026 at 4:59am
Topic: Tru-Power 4 1/8 complete kit
Posted By: TennMatt1
Subject: Tru-Power 4 1/8 complete kit
Date Posted: 04 Apr 2016 at 9:57pm
Anyone have any experience with what kind of power this would put out in a wd-45..226 ci? I have it in mine I found out in the 45 block and I know it's stout. Just wondering others experience.
1954 WD45
Posted By: DrAllis
Date Posted: 04 Apr 2016 at 10:05pm
What is your cranking compression pressure ?? 120 pounds or 180 pounds ??
Date Posted: 04 Apr 2016 at 10:32pm
180
1954 WD45
Posted By: DrAllis
Date Posted: 05 Apr 2016 at 8:32am
Well then, you have the compression of a One-Seventy engine plus a 1/8" overbore, so you should have 67 to maybe 70 flywheel HP at 1650 loaded RPM depending on what your carb is.
Date Posted: 05 Apr 2016 at 9:07am
I have a tsx 464 that will run with just a plug in the bowl to keep gas from running out.Tractor will turn 3000 rpm's. I know I pulled 4500lb last month and it spun out at the end of the track with 14.9x34 michelin radials. You think I could benefit from a bigger carb? Or is there anything else I could change or do to get a little more? Pulled it in 5 500 lb one time and got to the end of the track and spun the clutch out. It is extremely stout for a "factory engine".
1954 WD45
Posted By: DrAllis
Date Posted: 05 Apr 2016 at 11:28am
A larger carb will add more on the top end, yes. You think yours is stout?? imagine the same set-up with 240 psi of compression.
Date Posted: 05 Apr 2016 at 12:46pm
Aw yeah we got a guy who's got a compression release on his cause starter won't turn it over....but he's got about $12k in his engine. Mine just surprised me and since I have no pto anymore I don't have a way to dyno it. My tractor actually has 190 lb compression.
1954 WD45
Posted By: Charlie175
Date Posted: 05 Apr 2016 at 12:54pm
My D17 cranks about 210-215 and with the stock starter, you can tell it.
I was a doofus as when I rebuilt it, I left the carb settings as is. Ran fine I thought. Over the winter I decided to play with the load adjuster and I must have been way off on what it needed cause I am out almost to the end of adjustment before it started to stumble and I backed off a bit. Responds to throttle much better now on a steep hill, can't wait to hook it.
Sorry to hijack!
Charlie
Date Posted: 05 Apr 2016 at 1:04pm
Are these the kits you are talking about?
https://tiscoparts.com/part-finder.html/?find=allis-chalmers-tractor-wd45-engine-overhaul-kits-40433032" rel="nofollow - https://tiscoparts.com/part-finder.html/?find=allis-chalmers-tractor-wd45-engine-overhaul-kits-40433032
Charlie
Date Posted: 05 Apr 2016 at 2:26pm
Yes Charlie175. Mines the complete kit...valves,lifters and all. Mine has been in for some time now and I'm wondering if I should re-ring it. I also run 110+ fuel in it and the inside of my block is like a light caramel color. No suuut or anything.
1954 WD45
Date Posted: 05 Apr 2016 at 3:27pm
Did you have to change your jets to run the 110?
If you have 190 psi I can't imagine needing a ring job
Charlie
Date Posted: 05 Apr 2016 at 4:26pm
I haven't changed anything about the carb...it was built when I bought it. The boy who bought it done so because his 150hp super h was getting 30' put on him when it had 14.9x28 in Farm stock. I know my my main isn't much more than the threads left it's been reamed out so.I run the 110 in all my small engines as well. No ethanol and clean burn.
1954 WD45
Date Posted: 05 Apr 2016 at 6:05pm
OK. Never tried it before
Charlie
Date Posted: 05 Apr 2016 at 9:05pm
It's good stuff..I get it at my machine shop. Been shopping there a long time!lol
1954 WD45
