Print Page | Close Window
200 PTO shaft removal
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=119381
Printed Date: 23 Aug 2025 at 10:10am
Topic: 200 PTO shaft removal
Posted By: HD6GTOM
Subject: 200 PTO shaft removal
Date Posted: 23 Feb 2016 at 11:43am
Guy has had the pto shaft out of the 200 to work on the Hydraulic PTO clutches Now trying to get it apart again-- to go back in for more work, but the PTO shaft wont come out. Does anyone have any suggestions? Thanks.
Posted By: HD6GTOM
Date Posted: 23 Feb 2016 at 12:27pm
After some more explanation on his part, I think this is a shaft that has to be pulled to remove the hydraulic pto clutch pack from the bottom of the tractor, not the actual PTO shaft sticking out of the back of the tractor. Thanks Tom
Posted By: DougG
Date Posted: 23 Feb 2016 at 6:21pm
Prolly got to pull it out of the front of under the Powerdirctor, if its hydraulic activated; becareful, its heavy!
Posted By: HD6GTOM
Date Posted: 23 Feb 2016 at 7:41pm
Thanks Doug, he had it out 3 months ago, now he has to go back in to find out why we are low on pressure, probably a seal, can't get the shaft to budge out the front. He has to fix 3rd gear. Can you get to this stuff from the top? Tractor has factory cab, does the cab have to come to fix this? Would it be easier to drop the tranny and fix PTO and 3rd gear with the tranny on the cement floor?
Posted By: DSeries4
Date Posted: 23 Feb 2016 at 9:40pm
The PTO is separate and not in the transmission.  It is at the bottom of the torque tube just behind the clutch housing.  That is the easy part of the job.
If he is trying to fix 3rd gear because it is jumping out, the entire transmission will have to come out and get torn down to get fixed properly.  There is nothing that can be done from the top to fix the issue.  I never had to deal with a cab tractor, but I assume it might be best to remove the cab in this case.
Posted By: MACK
Date Posted: 23 Feb 2016 at 9:44pm
Cab does not have to come off.
 To get PTO housing to slide forward, the two dowel pins have to be pulled out first.
 Trans. and PTO are not togather.  MACK
Posted By: HD6GTOM
Date Posted: 24 Feb 2016 at 2:37pm
Thanks guys   Tom
