Pre series d-17? |
Page <123 |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8654 |
If anything,a loose plug wire will make a hotter spark at the plug electrode but I'd bet you couldn't prove it on a dyno. Loose fit VS snug.
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1172 |
It seams to sound like it misses a bit but all my ac tractors do this... |
![]() ![]() I'm wondering why I have what seems like a supply and return line on my d-17 in these two pictures it shows the rear and then the side of the tractor where the lines go into? anyone seen this before or is this how all of them are? |
Scott B ![]() Orange Level ![]() ![]() Joined: 14 Sep 2013 Location: Kansas City Points: 1051 |
They all have them. They original were both steel. Your rubber hose is a replacement
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Ok, but a d17 is a power raise only correct with no hydraulic power down?
frnkeore ![]() Silver Level ![]() Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
Those lines are for a hydraulic cylinder on the implement.
Quick couple is pressure and the rubber is the return line. |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
So this system of pressure and return line is what benefit compared to let's say my CA with only a pressure line?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22059 |
Someone has added that to the tractor so that they could connect a two-way cylinder and have a breather for the second hose thru the tractors hydraulic sump. No advantage over the D-14, except you can use a two-way ram with no modifications.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8535 |
Matt,
Your D17 has about the same patina as mine. I see you have the top link attachment added. Looks similar to what I built. I found that I would have liked to have my eyelets up on the top allowing a couple more inches for the top link. I could barely get my brush hog hooked up. Regards, Chris
Page <123 |
