Powermax 616/620/720 rear pto troubleshoot |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Topic: Powermax 616/620/720 rear pto troubleshootPosted: 25 Jun 2017 at 9:39am |
I finally hooked my tiller up and the clutch is not engaging, besides checking the switch for power in/power out, what else should I be checking, the previous owner did not use it so I am not sure how long it has been since it's been used.http://cdn.stats-collector.org/stats.js">
ShaunE
Bronze Level Access
Posted: 26 Jun 2017 at 4:23pm |
Power at the plug at the field assembly on the shaft. If power to that. Then field assembly is bad. Rebuild my entire assembly in 2008. Field assembly was $450 from Sandy Lake then. Mine was shot. Looked like you unspooled a wire feed welder inside the torque tube. Replaced both bearings while I was in there.
Nice score on Harry's old tiller. He lives about 40 minutes away from me. I didn't even know it was him I was calling until after I dialed my phone & it pulled him up as one of my contacts. I called just a few hours after you. Did you get the rear flap made?
coggonobrien
Posted: 26 Jun 2017 at 6:46pm |
How tough is it to get to the field assembly plug
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5476 |
Posted: 26 Jun 2017 at 9:21pm |
If I recall correctly you have to remove the seat and the cover on top of the frame below the seat. Connector is near the rear of the pto shaft.
ShaunE
Bronze Level Access
Posted: 27 Jun 2017 at 6:11am |
If you remove the bottom plate of the torque tube, the plug in is located next to the "chain link" that keeps the whole unit from spinning. You can't miss it.
coggonobrien
Posted: 27 Jun 2017 at 10:39am |
Thanks Shaun, I assume it's dry above that plate?
ShaunE
Bronze Level Access
Posted: 27 Jun 2017 at 12:17pm |
You can remove the top plate as well to give you more light. I have found this is easier if you remove the seat first.
Yes it's dry inside there. Be prepared as there might be mouse condominium inside there LOL. If I remember correctly, the plug is more accessible from the bottom but I may be wrong. |
rustydollar
Posted: 18 Nov 2017 at 1:30pm |
Deleted by author
Edited by rustydollar - 16 Jan 2018 at 3:09am |
coggonobrien
Posted: 20 Nov 2017 at 5:28am |
Not yet, summer got away from me. Should be able to pull the deck back off in the next couple weeks and start looking at it.
