Power Washing |
Page 12> |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Oct 2011 at 5:34pm |
questions. Alright y'all I am not an expert trying to clean baked on grease from an old engine. How do experts do this? I used a cold water gasoline fueled high pressure washer and pretty much it didn't do squat. I scraped with a putty knife on my XT for 5 hours. I scrubbed engine degreaser with various brushes. It is still dirty. The tractor is a late 1970 which was parked in a shed in 1987. The good is it only was active 17 years. The bad part is it has just sat for 23 years. But what does it take to clean...steam? How do you pro's do it? Thanks, Dana
The front tires I think said 1100 x 16. They look too big. I am going to put all new tires on her. Can I go smaller on the front with these rims? |
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
i use oven cleaner[let it soak] withlots of air movement moving
Here's one I tried out yesterday. The painter knew how to get her clean before painting. |
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=39388&title=degreaseer
Go to the bottom of the page to see my results with oven degreaser. This was from whiping it with a rag
German Shepherd dad
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
dana, i know you already have plans for this great find but i would leave it just the way it is. she looks best in her work cloths and i LOVE the tall front 3ribs in the 190s they go gud with the 38'' ?? rears. thats my dream tractor. keep the pics comming plez,hm
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
I have 1100-16s on my 4020. Definitely a tall tire bur I think saves front spindles from shock when I hit plow furrows or badger holes. And gives better front axle clearance for cultivating and spraying. The 4020 came with 7:60-16 which were too small, I think.
For a bit smaller tire look at a 11L16. It won't stand up so high but still fits the 8" wide 16" rims. Most often seen as a wagon tire though but I think Its available as a tractor front 3 or 4 rib. Gerald J. |
Hey ACWD45 nice results. If I spray oven cleaner how long to let soak? And then can I rinse with water?
I let it soak for 10mins-1/2 hour. don't do it unless you're going to re-paint the tractor though.
German Shepherd dad
AllisChalmers37 ![]() Orange Level ![]() ![]() Joined: 11 Jul 2010 Location: London,KY Points: 1846 |
Laugh at me if you want but I found that the best thing is the Orange Goop hand cleaner. Just spread it around on the tractor and then you can scrub it and then wash it off. I did this on a 424 IH that had over 40 years of grease and diesel fuel caked on it and it did an amazing job.
LionelinKY ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Radcliff,KY Points: 695 |
Dad's 190XT has 10.00X16 up front with 18.4X34 rears-looks good too.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
A hot pressure washer works grteat to remove caked on grease. I also used oven cleaner when I painted my WD45. Take the sheet metal off first so you can get the rest clean. |
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
i will have to wholeheartedly with acwd45.i have found if you use the oven cleaner,it is best to use it in hot sun light,it will work much faster.oven cleaner will take it down to the bare metal,much like paint remover.i have 6 wd45,s,gasd and diesel i have used it on and the results were good.wash it off with at least a 3400 psi pressure washer,and your done...oh yes keep the pressure washer away from gaskets,such as manifold gaskets and rocker box gaskets...they will disappear...
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Yes you can rinse it off with water. Or scrub after letting it soak, with a water wet brush. Dusty
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7515 |
My XT came with 7.5 x 16s on it, but I got a set of 10 x 16s with rims from a 200. Looks a lot meaner now. 10 x 16 on your rims should not be a problem.
Regarding the cleaning, last year a sprayed my 175 down with a bunch of Super Clean degreaser and let it work for 15 minutes or so, then took the pressure washer too it. Did a great job!
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
that's a pretty good lookin tractor for sittin so long!
Thanks for all the help. Shameless yesterday was the first sunlight that has beat down on her in 23 years!
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
Drive or trailer it to town and run it through the car wash. I have washed many a tractor that way. The hot water and soap will cut the grease and dirt and will save the paint. |
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Thats a nice tractor Dana!
Bull ![]() Orange Level Access ![]() Joined: 28 Sep 2010 Location: Lamar, Missouri Points: 589 |
Sometime back there was discussion here about using a needle scaler to remove the "concrete" grease from old equipment. I bought one from Harbor Freight for about $30.00. It was some of the best money I ever spent, it will knock out the caked on grease in a hurry. I would suggest hearing and eye protection when you use one.
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Oven Cleaner and Scrubbing Bubbles....2 best degreasers EVER.....just watch because oven clean will take loose paint right off lol
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Brian F(IL) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Paxton, IL Points: 2719 |
For cleaning, find a buddy who has a Karcher steam cleaner. Depending on how high he's got his pressure set, you have to be careful not to remove existing paint and/or decals.
BTW, I like the larger tires on the front. FWIW
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Orange hand cleaner mixed with a little dish detergent works good.
Spread it on and brush it in. Do this in the morning. Later in the afternoon brush in some more. In the evening hit it with the brush again and then pressure was it. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Opps Edit
I'm Sorry!!! [IMG]http://i978.photobucket.com/albums/ae263/nemf/Baby-Cryin In the evening hit it with the brush again and then pressure WASH it. |
Oops Edit.
That didn't work. I'm Sorry!!! ![]() In the evening hit it with the brush again and then pressure WASH it. |
farmtoybuilder ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Steam Cleaner if you have access to one. Sure miss ours!
Jeff(WD45-SATX-TN) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Anyone ever tried Simple Green. Do not dilute, if parts are left in uncut liquid for 24 hours or so it will remove paint. Used it over the weekend to clean up my brake shoes and seat assembly parts. Let them soak for 10-15 min or so, then scrubbed with a wire brush. There was actually orange paint under all the dirt on the seat assmbly. I had planned to remove the grease and dirt then bead blast. There was more orange paint under there could not bring myself to blast it away.
1954 WD45 NF "Iron Tater"
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88268 |
oven cleaner--- then go to the car wash and use the pressure HOT washer.
Pressure Washer ![]() Bronze Level ![]() ![]() Joined: 26 Mar 2012 Location: Orlando, Fl Points: 2 |
I reckon I'd give ole purple power and a good pressure washing a try.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
Hey Pressure Washer
How far are you from Port Orange, FL Gary
Page 12> |
