Power steering replacement problem |
Post Reply |
Still.learning
Bronze Level Joined: 19 Mar 2019 Location: Minster,ohio Points: 7 |
Posted: 25 Feb 2020 at 7:05pm |
Hello, I put a used power steering motor, that appeared identical , in my AC 7060 and it turns about twice as fast to the right than the left. Anyone no why? Thanks
Dave H (NE)
Silver Level Joined: 11 Sep 2009 Location: Western NE Points: 285 |
7000 and 8000 series tractors use a regeneration type orbit motor get a used one from one of them.
MACK
Slot of steering motors look alike but can be a lot different. MACK
PeteMN
Bronze Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 192 |
Our 8050 steering unit was leaking so we took it apart and put new seals in it. When we started the tractor the steering wheel almost broke my hand when it started turning one direction. I tried to turn it back but it would immediately turn the other way going til it hit the stop. I thought maybe I had hooked the hoses up wrong, but they were correct. So we took it apart and reassembled it slightly different than we did the first time, that cured the problem. But it will still leak for a while if its been sitting over winter, neighbor had the same problem with his 8050 steering unit.
Orange Level Access Joined: 12 Sep 2009 Points: 19572 |
You need to find one from a 7010 thru 7080 tractor, which is identical to your old one.
Jack(Ky)
Orange Level Joined: 12 Sep 2009 Location: Ky Points: 1151 |
PeteMN They have timing marks on all the parts. You are very lucky to get back in time that easy without knowing where the marks go.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Reply | |
