power steering pulley dd grader |
sparky52
Topic: power steering pulley dd graderPosted: 07 Feb 2019 at 8:46pm |
What are the chances of finding the pulley that bolts on to the 3 grooved front crankshaft pulley on a dd grader, wanting to install power steering pump. Page 162 of parts book shows this pulley, part number 70660822.Would appreciate any feedback.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55255 |
Posted: 07 Feb 2019 at 9:12pm |
You might try Wengers, Myerstown PA, they usedta have some DD parts...
sparky52
Posted: 07 Feb 2019 at 9:41pm |
Thank you Dave
Ross D.
Joined: 02 Sep 2013 Location: Erin, Ont. Points: 339 |
Posted: 08 Feb 2019 at 8:06am |
Hi. I had my P.S. pulley made at a machine shop. Take the existing pulley with you so they can match. Ross,
Ross D.
Posted: 08 Feb 2019 at 8:27am |
Sparky, were you able to get some pictures of your new-to-you grader? We all love pictures.
Be sure to check the front mounted steering gear box. Parts are extremely hard to get; so, check this gearbox for leaks and proper gear meshing. Ross. |
sparky52
Posted: 08 Feb 2019 at 4:39pm |
Hey Ross, thanks for the information, I knew the machine shop was were I would probably have to go , but thought I might try the forum first. My son works for a oil company in Port Arthur Texas as a machinist. He has a couple of lathes in his shop at home, I have had him build a new hub for the new water pump so for. Seems to me if you are going to own one of these A C Graders you need a Mill and lathe. A donar machine would be handy also. I have yet to become familiar with what parts are available threw retail and salvage. As for pictures I was waiting to roll this little unit out with fresh paint before posting pictures. I have really enjoyed the A C forum with the mountains of information posted. Really appreciate your reply.
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 08 Feb 2019 at 7:03pm |
Might buy pulley and just machine bore to make it fit.Had a book on pulleys and made one once,Need correct angles and spacing for dia of pulleys.
Ross D.
Posted: 09 Feb 2019 at 9:34am |
Good morning. I could never understand why A C did not automatically put power steering on their 'D Special' graders. I have a 'D Special' and it was shipped with every option as standard equipment; except, power steering. We are currently trying to install this option.
It appears that a lot of option are available if you decide to put P S on. My parts book shows: ![]() There are, of course, so many options for appropriate equipment to adapt to the grader for P S. Automotive pumps with reservoirs , pumps driven from other sources like the distributor, most seem to have added a priority valve to the existing hydraulic system in order to rob enough oil to power steer. Here are some miscellaneous pictures. How do you intend to install the system? ![]()
sparky52
Posted: 09 Feb 2019 at 5:45pm |
Hey Ross, took your advice and did some surgery on the front steering box. After opening it up found some bearing problems. So decided to update to a later model steering box. Found that a steering box off a S10 has the same splines as the A C Grader, believe this is the way I want to go. Also want to mount automotive power steering pump so as to not rob fluid from main valves. This application is not as neat as I would like, but for long term I believe its the best.
David |
Ross D.
Posted: 09 Feb 2019 at 7:37pm |
Hi David. Here is pictures from an old grader that was at the Pontiac, Il. G.O.T.O. show this year. The pictures show an automotive style pump mounted on the R H side, driven off the crankshaft pulley, and located below the alternator. Sorry that the pictures are not very good and the sizing of the pictures. Here may be an idea that you might want to consider sometime. This man says that this addition to the blade angle really works well for fine grading applications. ![]() Ross. |
wfmurray
Posted: 09 Feb 2019 at 9:30pm |
Looks like putting pump on dist would be putting to much on gov gear and dis gear train. I know it was used as an add on on small tractors. I would go for the belt.
Ross D.
Posted: 09 Feb 2019 at 10:22pm |
Probably was a common usage: ![]() ![]() Ross. |
