Power Steering issue |
jpi72
Joined: 27 Jul 2019 Location: Hudson, Iowa Points: 48 |
Topic: Power Steering issuePosted: 14 hours 31 minutes ago at 9:25pm |
I have what I believe is a 610 Allis Chalmers forklift. It has a D15 Series 2 engine (160 cu. in.) When I start the forklift the power steering is really hard to turn. It takes quite a while of warm up before it works properly. The forks lift right away. Do you have any suggestions? Am I getting air into the system when it sits overnight?
Joel
Posted: 14 hours 10 minutes ago at 9:46pm |
In January of 2025 you said: "we do not suspect the pump". Back then, I told you I thought it was the pump. Yesterday, I again told you I thought the pump was losing its prime when it sits. I am visualizing a single TANDEM (twin) pump that has a problem in the power steering section and it may be at the driveshaft end of the pump, pulling air thru the shaft seal.
jpi72
Posted: 5 hours 35 minutes ago at 6:21am |
Thank you for the reply. I will study the pump better. I assumed it was just one pump.
Joel
Posted: 5 hours 26 minutes ago at 6:30am |
And I don't know because I'm not there looking at it. You can't have LIFT hydraulics and then have ZERO power steering if there is one pump. A priority/flow divider valve could be a possibility but your description doesn't make me think so. If there are two exit lines on your pump, it is a twin tandem pump.
Edited by DrAllis - 4 hours 44 minutes ago at 7:12am |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3608 |
Posted: 4 hours 2 minutes ago at 7:54am |
I have one that does the same thing if left sitting for a few days. The colder the weather the worse. The steering section is the one next to the drive - just like a series IV D17. There is a relief for the steering that dumps back to the intake pipe but don't think that is the issue. After a few minutes, it works fine. Lift works fine all the time. Common sump. It does have manual steering as the steering wheel is doing the steering with great difficulty.
