? power steering fluid Char-Lynn |
Michael Welch
Joined: 14 Sep 2009 Location: Jasonville IN Points: 28 |
Topic: ? power steering fluid Char-LynnPosted: 25 Jan 2012 at 8:19pm |
I have a WD45 with Char-Lynn power steering what kind of fluid do I need? Thanks Michael
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 25 Jan 2012 at 8:22pm |
i use dextron in the power steering on my WD45. |
ctbowles58
Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
Posted: 25 Jan 2012 at 8:55pm |
"back in the day" thay used ATF type F
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 26 Jan 2012 at 7:45pm |
Automotive ps fluid or Hydraulic fluid will work with the char lynn unit. The pump is the same as used on Ford and Chrysler cars in the 50's. You do not need the additives in the transmission fluid.
Michael Welch
Posted: 26 Jan 2012 at 8:26pm |
I'm having trouble bleeding the air out.
Rich--MN
Joined: 31 Jul 2011 Location: Ramsey,MN Points: 952 |
Posted: 26 Jan 2012 at 8:36pm |
Do not know if my D 17IV has that brand of steering pump, but when I replaced the bearings and after filling it with fluid, I cranked up the engine and had the air problem.stopped the engine and cracked the output line, recranked the engine and with oil squirting/spurting after a bit it was retighten the line to get rid of the air.
