Power steering dilemma
Farrell(Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Topic: Power steering dilemma
    Posted: 13 Feb 2012 at 7:19pm
My WD45 gas loader tractor has a Charlynn power steering unit on it that I have adapted to use with a Ford pickup power steering pump.  It works fine except that the power steering motor leaks bad as it needs new seals.  As luck would have it, I have a complete factory power steering unit off a WD45 diesel.  I am considering two options:  first, putting the factory power steering motor from the diesel unit on the tractor and using the Ford power steering pump to run it or second, repairing the Charlynn motor.  Does the factory power steering motor have enough advantages to make the first option attractive on the loader tractor?  Or, would it made more sense to leave both units as they are and either sell the diesel one as a complete unit or put it on one of my WD45 diesel tractors?  Thanks for the opinions.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:22pm
Woops, I forgot to add that the pump from the diesel unit could be used on a D17 diesel that I have.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:32pm
I would be inclined to fix the Charr-Lynn motor. I have a 45 with PS and although it's 58 years old I was never impressed with the "factory" PS. I'm not knocking it cause I know it could use a rebuild but I would think the charrlynn would be cheaper to fix and leave the Factory set up  complete.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:53pm
Where would you get a Char-Lynn motor rebuilt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:20pm
Buy a rebuild kit and do it in the garage.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:18pm
if you use the one off a 45-d,it was splined to the back of the generator...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:22pm
It has a common oring in each end. Just mark it to get back togather right. Take each end cap off leaving the shaft in place and replace the orings one end at a time.  MACK
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:45pm
the wd i had the pump replaced in i got a rebuilt one for 200 bucks after core trade in from parts guy i go through here in MN worked great  but i know if you don't get the plates lined up perfect or "timed" the motor wont work also if they get to wore out they get oval ed out and even a rebuilt kit wont work
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 7:01pm
Be very carefull using any aftermarket pump on the old steering units as late model automotive stuff may be too much flow or pressure for the oem setup to handle. It may work great, for awhile.....
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farrell(Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 7:19pm
Dave,
   I don't remember the year but I as I recall the Ford pickup was in the 1970s.  That is probably not enough information to know if the flows or pressures will be too high.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 8:07pm
Only with a flow meter and pressure gauge in each system to see what the flows and relief pressures are will you be able to determine if this can damage anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 8:57pm
Where do you get a rebuild kit for a Charlynn torque generator motor?
Edited by sparky - 14 Feb 2012 at 8:59pm
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 11:09pm
Id reseal the Charlynn  unit Farrell,  like Mack says, mark the end caps and do one end ata time.  If I remember right some of them have a quad seal.       Force America at Ft Dodge Ia has the seals, I dont have the phone # handy.  If you cannt find it PM me and ill do a search.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 11:24pm
Automotive power steering pumps are usually vane-type variable displacement units, in which case the vanes retract when 1) max pressure is reached or 2) when shaft speed falls below a certain point.
Excess flow or pressure really can't occur in a vane-type pump, and the advantages are that it doesn't require an external pressure relief valve, and doesn't impose much cranking load on the engine at startup, but the disadvantages are that they can 'stick' in a retracted state, and cavitation will annihilate the vanes and wear-plates in a hurry.
If the pump is a fixed-displacement (like a gear or georotor), the system MUST have a pressure relief valve, and the steering valve MUST be an open-center type valve, so that return flow has someplace to go, lest you stall the pump against the pressure relief valve anytime the steering wheel isn't turning. Fixed volume pumps were NOT commonly used on domestic automotive power steering systems, but they're frequently used on power equipment.
