Power Steering Control Valve. |
Post Reply |
MrH
Bronze Level Joined: 29 Sep 2024 Location: Moselle Points: 2 |
Posted: 5 hours 20 minutes ago at 12:12pm |
I have a D17 series iv and I just got the motor replaced. Everything is fine except the fluid is leaking out from the Power Steering Control Valve assembly. Actually, from around the worm shaft and the seal from the rear cover. I'm thinking that the seal needs replaces and wonder if anybody can tell me where I can get the seal.
Alvin M
Orange Level Joined: 24 Jun 2018 Location: PA Points: 755 |
AGCO Part # 70229725 they have it in stock
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7308 |
AGCO has the seal. You have to roll the axle out from under the tractor. Easy fix. Done many of them.
Alvin M
I just take the steering shaft off remove the coupler remove the cover then you can change the seal don't need to remove front end that way
Post Reply | |
