Power Director?? |
irlbeck A-C'S
Joined: 28 Sep 2009 Location: Crestview FL. Points: 689 |
Topic: Power Director??Posted: 09 Jun 2010 at 7:17pm |
You can move the shims from one side to the other. Just depends what side you need to repair. Just move the same amount from each stack to keep it all even. You can get to them from the access plate. |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6109 |
Posted: 09 Jun 2010 at 6:40pm |
Thanks for the tip, Rogers- is that adjustment made by adding shims? I take it they're accessible through an access cover?
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 09 Jun 2010 at 4:11pm |
Thanks Guys!
Rogers
Posted: 09 Jun 2010 at 12:19pm |
There are three different sets of shim stacks in the power director clutch. The the three sets of shim stacks are equally spaced around the power director clutch, and each shim stack is broken into three groups of shims. In each stack there are shim grouped at the center and to the front and back of center. These shim stacks are to be adjusted so that there is a specified amount of equal spacing between the preload plate and pressure plate in the engaged and disengaged positions. The service manual goes into detail on the adjustment which does not require splitting the tractor.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 09 Jun 2010 at 11:37am |
If I remember you can rotate the plate inside the clutch pack to give it a new surface to wear on but that might be for a WD. Have to look at one to remember.
Wink I am a Russian Bot |
DaveKamp
Posted: 09 Jun 2010 at 11:12am |
Bob- My Series 1 did this on the high-range. I asked Bill Deppe about it, and he showed me a spot in a power-director clutch pack that had worn... apparently the detent area... and once it wears a bit, it tends to cause 'em to pop out. He didn't mention any adjustment point... it is apparently an over-center detent concept. Unfortunately, you have to split the tractor to get it out, then weld up and machine the parts, and worse yet, even though the unit kicks out, there's no other problems, and will continue working indefinately, provided you tolerate or overcome the lever popping out.
Now, the poor-man's fix, is to take the little sector piece down by the shaft pivot, and mill or grind a little detent IN it... at which point, the director will stay in place by virtue of the new detent. My PD jumped out of high, which I initially solved by placing a foot on the lever, and shortly thereafter installed said detent. It's worked fine ever since. Someday, when I find that it's time to split and rebuild the PD, I'll probably weld that detent notch out and put it back to original state... or not... But I'm no expert here... I raked and baled with my grandpa's Series 4 for many years, and never knew much about it... but got this Series 1 last fall, so my actual work-on experience here has just been the last year or so. |
BobHnwO
Posted: 09 Jun 2010 at 4:06am |
bump
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 08 Jun 2010 at 7:14pm |
call your old dealer has to be an old dealer ship serviceman no proplem for them they have done 3 for us still working good
BobHnwO
Posted: 08 Jun 2010 at 6:58pm |
1958 D17,power director sometimes pops out of low,how to adjust??TIA.
