Power Director??
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Topic: Power Director??
    Posted: 08 Jun 2010 at 6:58pm
1958 D17,power director sometimes pops out of low,how to adjust??TIA.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 7:14pm
   call your  old dealer  has  to be an old dealer ship serviceman   no proplem for them   they have   done 3 for us  still working good
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 4:06am
bump
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 11:12am
Bob-  My Series 1 did this on the high-range.  I asked Bill Deppe about it, and he showed me a spot in a power-director clutch pack that had worn... apparently the detent area... and once it wears a bit, it tends to cause 'em to pop out.  He didn't mention any adjustment point... it is apparently an over-center detent concept.  Unfortunately, you have to split the tractor to get it out, then weld up and machine the parts, and worse yet, even though the unit kicks out, there's no other problems, and will continue working indefinately, provided you tolerate or overcome the lever popping out.
Now, the poor-man's fix, is to take the little sector piece down by the shaft pivot, and mill or grind a little detent IN it... at which point, the director will stay in place by virtue of the new detent.  My PD jumped out of high, which I initially solved by placing a foot on the lever, and shortly thereafter installed said detent.  It's worked fine ever since.  Someday, when I find that it's time to split and rebuild the PD, I'll probably weld that detent notch out and put it back to original state... or not...
But I'm no expert here... I raked and baled with my grandpa's Series 4 for many years, and never knew much about it... but got this Series 1 last fall, so my actual work-on experience here has just been the last year or so.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 11:37am
If I remember you can rotate the plate inside the clutch pack to give it a new surface to wear on but that might be for a WD. Have to look at one to remember.
Wink
I am a Russian Bot
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 12:19pm
There are three different sets of shim stacks in the power director clutch. The the three sets of shim stacks are equally spaced around the power director clutch, and each  shim stack is broken into three groups of shims. In each stack there are shim grouped at the center and to the front and back of center. These shim stacks are to be adjusted so that there is a specified amount of equal spacing between the preload plate and pressure plate in the engaged and disengaged positions. The service manual goes into detail on the adjustment which does not require splitting the tractor.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 4:11pm
Thanks Guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 6:40pm
Thanks for the tip, Rogers-  is that adjustment made by adding shims?  I take it they're accessible through an access cover?
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 7:17pm
 You can move the shims from one side to the other. Just depends what side you need to repair. Just move the same amount from each stack to keep it all even. You can get to them from the access plate.
