Power Director shaft seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Power Director shaft seal
    Posted: 22 Mar 2011 at 6:44pm
I see the seal or O ring on my Power Director has started to leak on my D17D. Is this a split the tractor to fix or can it be done with just pulling the side cover? Probably should do the PTO lever seal too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 8:06pm
Brian - thought I saw an earlier post (Dr. Allis?) say you can pull the snap ring off the PD lever shaft on the left side and push it to the right to remove & change the o-ring on the lever side then do the opposite to change o-ring on the left side.  I'm pretty sure the PTO lever is pinned to a fork on the inside and nearly impossible to do without splitting.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:23pm
PD can be done without splitting.  PTO can't.
