Power director: safe to pull? |
| Author | ||
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1343 |
Topic: Power director: safe to pull?Posted: 31 Mar 2023 at 9:05am |
Hi a’ll!
So I know the power shift not able to roll without the tractor running but how about the power director? Even with the 2 speed power shift? This question has been eating me away for awhile and in case I ended up with one that didn’t run… |
| Sponsored Links | ||
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 31 Mar 2023 at 9:12am |
I put my D-14s tranny into neutral and they roll fine...PD's always in high (fwd)
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8479 |
Posted: 31 Mar 2023 at 9:23am |
If you’re talking about a 7/8000 series they will roll unless the range box is in park.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 31 Mar 2023 at 9:58am |
As Creston said, they'll roll unless in park. I'm not sure about how far you should tow one, but around the yard or whatever, no biggie. And these 7/8000 series don't have a PD neutral, they go to low once you push in the clutch, and engine off.
55allis
Sorry I did mean the 7000/8000 series…
55allis
Posted: 31 Mar 2023 at 11:23am |
So even if it’s been sitting for a long time (let’s say 20/25 years)? |
Tbone95
Posted: 31 Mar 2023 at 11:58am |
MACK
Posted: 31 Mar 2023 at 1:17pm |
What tractor are we talking about? MACK
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 31 Mar 2023 at 2:39pm |
My 185 Manual says
If the tractor must be towed from one location to another the transmission must be out of gear, engine must be running, and the power-director clutch must be engaged in either high or low range. The above instructions must be followed otherwise the transmission will not receive proper lubrication. |
bigal121892
Posted: 31 Mar 2023 at 6:20pm |
The neighbors towed their 7080 about 3 miles; took out the pinion bearing, due to lack of lubrication.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 725 |
Posted: 31 Mar 2023 at 7:48pm |
If im not mistaken the rear end is pressure lubricated. If it were me id get a wrecker with a axle lift to pick up the rear end and move it that way
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
KJCHRIS
Posted: 31 Mar 2023 at 9:48pm |
Sounds like a question for a model specific Operators Manual.
Without knowing the model it's a hard question to answer.
plummerscarin
Posted: 01 Apr 2023 at 7:43am |
From my 7060 manual
Transmission (no difference) in neutral. Range transmission in neutral Towing speed (in capital letters) not to exceed 5mph. Distance not to exceed one half mile for an inoperable tractor. If the engine is operating, engine speed is 1200 RPM minimum to provide lubrication to transmission/rear end.(book states moving parts) |
55allis
Posted: 01 Apr 2023 at 8:47am |
That does sound about right plummerscarin…
Sorry Mack, I’ve been looking at a 7580 that pretty sad looking (lol)… It would only be rolling to/ on a trailer… ![]() Thanks a’ll for the replies!!!
DougG
Posted: 01 Apr 2023 at 1:11pm |
Awe doubt youd hurt it,, roll on
plummerscarin
Posted: 01 Apr 2023 at 3:16pm |
That looks like a project
MACK
Posted: 01 Apr 2023 at 8:34pm |
Trans in neutral, range trans. In neutral and you should be good to load and get into shop.
After you get her going, don't take it down the road until you've driven it around slow to get oil into range gears. MACK
55allis
Posted: 01 Apr 2023 at 10:23pm |
Haven’t got it yet because it’s on an auction and only if it goes cheep….
Don’t even know if the engine is any good being the owner thought he blew it up… Said it blew black smoke all over and he shut it down, but that was 25/30 years ago. |
Posted: 02 Apr 2023 at 7:31am |
Might have just been the turbo, but surely will be an OH now. The muffler didn't remove itself.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1537 |
Posted: 02 Apr 2023 at 7:33am |
That ooks like it could be a fun project. Sheet metal looks straight
55allis
Posted: 02 Apr 2023 at 8:39am |
I did notice it has the famous crack in the manifold but it is also missing the engine dipstick and bottom of the air cleaner…
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 02 Apr 2023 at 1:43pm |
It appears to be a late serial number tractor. Bosch injectors. No, don't pull those tractors very far,they use pressurized oil for critical transmission bearings, bushings, and such. Shame to see machines fall into such disrepair. The day that it failed would have been a better time to get rid of it. At that time, it would have still had decent value. I would expect it to be cheap and as a buyer,it better be.
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 02 Apr 2023 at 4:42pm |
Running when parked, knee deep in rubber, no low ball offers, I know what I've got! ![]() Then again, if the price is right. |
55allis
Posted: 02 Apr 2023 at 6:48pm |
Haven’t decided on a price yet but here’s a picture of the serial number….
Lynn Marshall
Posted: 02 Apr 2023 at 7:49pm |
That's the cab serial number, not the tractor number.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 02 Apr 2023 at 8:40pm |
Even scrap price by weight would be more than I'd give. For what you're gonna have in it you'd be ahead to pay for a GOOD runner.
55allis
Posted: 02 Apr 2023 at 9:24pm |
Sorry, guess it doesn’t have a serial number listed… I guess I forgot that those Allis’s had it printed in the rear end (I think)… |
55allis
Posted: 22 Apr 2023 at 6:06pm |
Well it sold for $280, and no I didn’t buy it…
Thought others might want to know… |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5472 |
Posted: 22 Apr 2023 at 6:32pm |
Don’t get any cheaper than that. Could have made some cash off of it.
