Power crator vs Flats
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Power crator vs Flats
    Posted: 30 Dec 2014 at 3:24pm
Just wanted to show the difference between a D17 PC (4") and a WD Flat Top (4.125")
Charlie
OrangeFever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeFever Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 7:44pm
Are the wrist pins in the same locations?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2014 at 9:12pm
The top photo has the pin through both. The flat top is a little shorter but from the pin to the bottom is the same.
Charlie
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 7:44am
Looks like the edge might be taller but the dish looks lower and that makes the dish lower compresion piston
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2015 at 6:54pm
4" D17 power crators have a psi rating of 140 that I have seen.
The Flat tops in my 17 are at 205 to 210 psi.
Charlie
