Pouring Lead Bearings, HELP please
rumleyallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rumleyallis Quote  Post ReplyReply Direct Link To This Post Topic: Pouring Lead Bearings, HELP please
    Posted: 28 Jul 2011 at 9:22pm
Our old 30-60 Oil Pull needs a right rod bearing poured for it, we have the lead blocks but no knowhow on how to rebuild this old engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:26pm
Babbitt is what you need. Not lead. If you haven't done it before, might should have a professional do it. Not that hard, just need patience. HTH Tracy Martin
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:31pm
Send some money to Lindsey Publications. This is 1 of 3 books they publish.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rumleyallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:33pm
thats the problem there arnt any professionals around, and now that you mention it these bricks were there to fix the bearing. but like i said how do you go about it, or is there anyone around South Central Pa that can pour them
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:41pm
I thought they were about gone too but found a nice shop near darned near in my back yard, well a couple hours away. Harts Machine in Cecil Ohio. Ask for John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 9:43pm
What I have found is the guys that know how to do it, don't spend anything on advertising. Ask anybody you meet that has an old tractor where you can have Babbitt bearings poured. My old boss read up on pouring Babbitt and then tried several times to pour bearings for his 1907 Hart Parr. I ended up making split bearings out of 660 bronze.He did find some help when he started working on the Aultman Taylor. Getting the heat right and preheating your assembly is muy importante.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rumleyallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 10:05pm
Hey, thanks guys. Does anyone know what the dimensions for this bearing would be by chance
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 10:38pm
You might check to see if there's a Model A Ford club in your area. The Model A engines run Babbitt bearings, and engine rebuilders have the capability you need. BTW, add your location to your profile so we know where you are - will make it easier to help you.
WC, CA, D14, WD45
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 11:09pm
I'd give Fred a call, if anybody would have a handle on who can do it Fred would, and he is just about a neighbor of yours
Somebody have Fred's shop number? I have it somewhere, but can't find it right now
Edited by LouSWPA - 28 Jul 2011 at 11:15pm
I am still confident of this;
Wait for the Lord;
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2011 at 11:35pm
All the savy Model A Ford engine builders now just machine them for insert bearings out our way.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 12:11am
   Try these guys :http://www.andersonofrosholt.com/
  Oh, and Rumely is spelled with the "E" before the "L", FYI.
http://www.rumelyallis.com
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 2:52pm
Why would anyone want to destroy the historic value of the A. Not to mention the fact that Babbitt bearings protect the journals a lot better than modern bearings. Why not just drop in a 302. Though exaggerated, it equates to the same thing. You've changed the fundamental design of the engine. Maybe I'm a purist but if you are not going to restore something right, give it to someone who will.
Edited by mdtractormechanic - 29 Jul 2011 at 2:54pm
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 3:02pm
Because nobody around there knows haw to do it, but they do know how to machine.
Edited by Rawleigh - 29 Jul 2011 at 3:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rumleyallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 3:59pm
Thanks for the links guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 4:23pm
Hmmm - there are several Model A engine rebuilders in my area that do Babbitt bearings. Personally, I suspect that they are as "savy" as rebuilders elsewhere in the country.
WC, CA, D14, WD45
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 5:05pm
717-451-6590 is Freds # Uncle Bill has done it or knows were to get it done.  Lots of steam guys around here.
The universal answer to all questions is yes, how much do you want to spend?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 9:28pm
You can look in the Green Magazine or Two cylinder magazine. There are advertisments in both of them The JD guys run into that all the time. Bob
Dennis (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 10:08pm
RumleyAllis,
You might want to give Bob a call @ http://www.bbdistributing.ypgs.net   he used to be a frequent adviser on this site...but I have not heard from him in quite some time...course over the years many others have come and gone also.
Dennis
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:41pm
smokstak.com
should be some help here too if you are still looking.
Thanks
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:55pm
B & B has burnt to the ground, and rumor has it that he's now a scrap man.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:19am
Darrel,
Thanks for the correction...I had no idea!
-Dennis
This page was generated in 0.168 seconds.
