Unofficial Allis Homepage
Forum Home Forum Home > HELP! > Forum Support Only - No Tractor Questions
Posting to make 'LINKS' appear and YouTube Videos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Posting to make 'LINKS' appear and YouTube Videos
    Posted: 27 Feb 2017 at 11:29am
In the response 'Message' window at the bottom of the page, you will see some icons above in the header bar.
You click on the green/blue world with a chain link...
In this window, the "Hyperlink Properties", which opens, you will see the following;
Link Type: [ Hyperlink or Email ]
Address: [ various links to choose from ]   [  **  ]  [ Preview Button ]
Preview: [  ***  ]
In the second row, the [ ** ] empty line, this is the place to add the URL that you have copied.
After you have 'pasted' the URL, hit the "Home" button on your keyboard, or hit the left arrow key to take you all the way to the beginning of the URL you pasted.
Now DELETE the first part of it all ( http://  or https:// ) as this is in the preceding "Address:" link window.
Then just click on [ OK ]  and it should appear.
For YouTube videos to appear.....
1 Go to the bottom of the page, to the 'Message' window.
2 In the Header bar at the top, you'll see the white box with and arrow pointing up to 1 o'clock.  Click on it.
3 The 'Message:' window that opens shows a lot of different things you can use to modify your message.
You HAVE to have the WYSIWYG enabled to use this!  It is availabe to you.
    WYSIWYG.....What-You-See-Is-What-You-Get.....
    Go to the 'Member Control Panel' in the upper left part of the page.
    Click on that and then go to the Forum Preferences and click there to open it.
    Go down to 'Enable the WYSIWYG post editor ' and check to see it is turned ON. (Yes)
4 Go to the top of the header and click on the piece of film strip (8th thing from left)
5 In the window that opens, 'paste' the URL from the YouTube page in the: YouTube File Name: [    ]
6 NOW go to the beginning of that line. You will see: https://www.youtube.com/.......................
7 Delete the s from the https://
8 Click on OK and the video will show up on the original page.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2019 at 5:41pm
Preview: [  ***  ]
Then click on the right box that has http:// and scroll down the the same one you just deleted previously and click on it.  Most if not all today are https://.
Quick Reply
Name:
Message:
   NoFollow is applied to all links from this forum
 Enable BBcodes
Security Code:
Code Image - Please contact webmaster if you have problems seeing this image code  Refresh Refresh Image
Powered by Web Wiz CAPTCHA version 4.04 wwf
Copyright ©2005-2013 Web Wiz
Please enter the Security Code exactly as shown in image format.
Cookies must be enabled on your web browser.
