Posting Pics
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Posting Pics
    Posted: 02 Jan 2011 at 9:50pm
Why not download and use Irfan View??  This is the easiest photo software out there for this sort of thing!!  http://www.irfanview.com/
You can open your picture in IrfanView and then go up to 'Image' then down to 'Resize'Resample' then go to the right side and choose any of the choices including 'Half' then just save the pic and upload it to here.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:10pm
One tough machine there Dave!
1954 WD45 NF "Iron Tater"
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:04pm
Well, that one worked the correct size, so guess I need to figure out the resizing thing in photobucket now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:00pm
ah, got it to post, but not in the larger size, so need to play with it I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:56pm
well didn't work, but seem to be getting closer
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:46pm
Dave, just click on the image code when it does that, it should copy it automatically now and say "copied".  Photobucket did update a few months ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:40pm
It doesn't let me copy the image code.  When I move the cursor down, it goes into the hand shape and treats the image code like an internet link.  Do I have something set wrong with the page or something.  It never used to act like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:37am
Dave, don't right click on the picture. Just hold the cursor over the picture, then go down and copy the image code and come back to your reply box and paste it.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 8:31am
Reset size in your camera.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 7:45am
When I post pics I email them to my self. When it asks if I want to shrink them to make them go faster I click that option then lable them resized and put back in my pics to post on the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 7:44pm
Sky, resizing isn't the issue.  I don't seem to be able to click on the picture anymore and be able to copy it into the forum.  Don't understand what is going on?
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 11:12am
AdamA, got your pics, hope i can move a 8070 2wd axle forward! Thanks Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 10:17am
Dave - if you are logged into photobucket you can resize the photo directly.  First log in, select the album (if you have albums), then click the picture to pull it up.  Move the mouse over the picture and a command bar will appear the top.  One of the commands is "resize" move the mouse over that and and a drop down menu with size options will appear, click the size you want to resize the picture.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 10:12am
I can't get the copy to work in photobucket.  When I right click it does not give me the copy option.  It says global settings and a couple of other things, but cannot get the copy option anymore.  I haven't been on photobucket for a while.  Do I need to change my settings or something?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 9:44am
If you have the snipping tool in your version of windows OS then use that to copy your picture and save as a new file. This works to resize picture to easily post, also change picture format to jpg. as can be saved as that file.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 7:57am
I have found a free photo resizing website before.  I quit using it though, as it was as much work as photobucket, and that is where I have my photos anyway.  With photobucket, you can set your photos to 'message board' size, so they are always the same size.  Once on photobucket, you just copy and paste the 'img' code, remove the 'img' from the front and back of code, remove the 'http' as this site automatically puts one on, and there it is.
Greg Kroeker
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 7:41am
ok I'm sure this has been covered before but can't seem to upload pics all mine the file size is too large any help? pm me if you want
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
