Posi-traction |
Page 12> |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6500 |
Topic: Posi-tractionPosted: 26 Jan 2019 at 9:17pm |
Did the 89 2wd F250's come with a positive traction or limited slip differential? Mine only drives one wheel and will get stuck on wet grass. My 87 F150 drives both rear wheels and gets far better traction. Guess I need to look up the VIN and see what it is supposed to have. And NO, Shameless, I don't need a Chebby.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 26 Jan 2019 at 9:43pm |
Hubert, you could get it both ways. A limited slip is a two edged sword. While working good in mud, wet grass and the like, they're very dangerous on ice. They'll get you making dough nuts before you can spit, and the stiffer the suspension the worse the are. so how much ice driving do most of us do? Probably not a whole lot if we can avoid it. Mud, yes.
Joined: 11 Sep 2009 Location: illinois Points: 88516 |
Posted: 26 Jan 2019 at 9:47pm |
there should be a sticker on the drivers door... there are several "codes" listed on the sticker... there is one called AXLE that has two digits or a letter and a digit.. that will tell you the axle ratio and if it is conventional or LS unit.
I had a 89 F250 and it had a LS unit with a 4.11 gear ratio.
Edited by steve(ill) - 26 Jan 2019 at 9:49pm |
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5108 |
Posted: 26 Jan 2019 at 10:49pm |
Hey Hubert, if you need an 86 F250 with the diesel let me know. I know a fella that has one. I see him every morning when I look in the mirror
shameless dude
Posted: 26 Jan 2019 at 11:21pm |
a buddy had one, he would gits stuck on a slight incline in dry gravel. he always had me come to pull his wagon loads of grain to what ever town he needed to go. one time I used a Malibu station wagon to pull his 300 bu wagon, he couldn't pull it with his ferd truck! took him years of embarrasement, but he don't buy ferds no more!
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8060 |
Posted: 27 Jan 2019 at 4:44am |
My 95 F350 had a limited slip differential and would spin on wet grass until you put it in 4 wheel drive. I believe the suspension and brakes and the weight forward on F series trucks made them work that way on slippery surfaces.
Posted: 27 Jan 2019 at 8:34am |
any Truck with Limit Slip will not have the traction of a 4 x 4.. Don't matter who built the truck. Trucks by nature are light in the back end.. They are made to haul heavy loads. Put a ton of fire wood or gravel in the bed and you see a big difference... That being said, my 1989 F250 with LS rear end went a LOT of places a Conventional Rear Axle would not go... But not nearly as much as my 2013 F150 4 x 4.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
Posted: 27 Jan 2019 at 8:40am |
My 83 Ferd has Ls and leaves the driveway no problem and so does Jenn’s Jeep. My GMC won’t cross a wet cow turd without getting put in 4x4 and it’s hit or miss if the chatty 4x4 buttons will work or not. Oh and by the way google will lead you to hundreds of thousands of the GM trucks with the same problems as mine.
thendrix
Posted: 27 Jan 2019 at 8:48am |
Those push button 4wd trucks are finicky. I had one and mine would go sometimes and not others. Wound up changing the servo motor in the transfer case and it worked right up until I traded. Pricey fix
Thad in AR.
Posted: 27 Jan 2019 at 9:06am |
The last switch I bought from Napa. I can’t remember the name but it’s been a good’en and same with the Fuel pump. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54407 |
Posted: 27 Jan 2019 at 9:16am |
As noted, posi don't mean much if yer empty. just get you 20' stucker...
Gordy
Posted: 27 Jan 2019 at 9:26am |
My 01 silverado had that 4wd switch problem pulled it apart looked at the circuit bd with magnifier had cracked solder around pins resoldered no more trouble.
Edited by Gordy - 27 Jan 2019 at 9:28am |
“If you can't explain it simply, you don't understand it well enough”
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 27 Jan 2019 at 10:01am |
I have one of those Chevys that will get stuck on wet grass. Only had to be pulled up a gravel driveway one time so I guess that's not bad for past 25 years.
1957 WD45 dad's first AC
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24776 |
Posted: 27 Jan 2019 at 10:15am |
REAL men don't need fancy 4WD or LS....... I used to drive my 67 stang FB all winter long and never got stuck... |
Hubert (Ga)engine7
Posted: 27 Jan 2019 at 12:26pm |
Tyler, thanks for the offer but I think I will stay with the '89. BIL gave it to me shortly before he passed so I don't have much invested in it. It stays at the farm and doesn't get used very much, but is nice to have around when I need to pull a trailer. I might check some junkyards and see if I can run across a used limited slip rear end cheap if I ever get caught up on my other projects. So far I have kept it out of places where I would get stuck.
Posted: 27 Jan 2019 at 4:05pm |
My 1989 F250 had the 351 and wide ratio ZF 5 speed manual... 2 wheel drive with LS unit.. You put 5-6000 pounds in the back end and drop it in LOW gear ( 6:1) with a 4:10 rear end and that thing would climb a tree...... Sure like the newer 4 x 4, but miss that old F250.
Edited by steve(ill) - 27 Jan 2019 at 4:05pm |
Walker
Posted: 27 Jan 2019 at 4:57pm |
4 wheel drive gets you 2 times stucker which only makes it 2 times harder to get unstuck because of all that extra stuckiness.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34341 |
Posted: 27 Jan 2019 at 5:02pm |
My 99 SD F250 FWD has a 7.3 auto in it, boat anchor dead weight in front end drives it into mud snow or sand like a nail. Tried wider tires just eats them up faster then the back end floats out, is as if needs duals on the Front!!
Edited by DMiller - 27 Jan 2019 at 5:02pm |
Walker
Posted: 27 Jan 2019 at 5:19pm |
Thinking back to my old rear engine VW beetle days with skinny tires that would go anywhere I'd question if you shouldn't have tried narrower tires. Not as much profit for tire companies but who cares.
Edited by Walker - 27 Jan 2019 at 5:26pm |
jaybmiller
Posted: 27 Jan 2019 at 6:38pm |
yes, tall ,skinny tires are far better than short, fat tires. I also had 300# steel in the back to offset the plow. Had 16" tall,skinnies on my CJ-5 and ,yup, could plow snow all day long, friend with same Jeep has fat( wide) 15" tires... got stuck a lot...the deal was a beer a pullout... I drank for free 1st winter.... !
cabinhollow
Posted: 27 Jan 2019 at 7:55pm |
I had the same truck, but with a 460. Unless you had 2000+ lbs in the back, you did not need to put it in low. And not to far away, there is a steep/straight/1 1/2 mile long hill. 4000 lbs in the back, 55 at the bottom,5th gear and you could top it at 75-80. gears 1- are we moving 2- I can walk faster than this 3- finely at 30 mph 4- 55-65mph 5- just passed a vet and red line on the rpm's is still along way off. I would do that every chance I got. Open 4-lane, that fast car would come up beside my old beatup truck and I would pull just a few feet ahead and stay there. I would have to backoff around 90mph as the steering would start to get lose. My 2001 F250, 7.3, 6 speed, is a baby, to that truck. Even empty, you have to hit the bottom of that hill, at 65, to make the top at 55. |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 27 Jan 2019 at 8:02pm |
WHY do they make a 1 wheel drive? My new (to me) Chevy Silverado doesn't have any LS either. In Wisconsin, that's not a good thing.... Dumbest thing I've ever seen. I too will be looking for a LS rearend.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 27 Jan 2019 at 9:09pm |
In about '76 or '77 I worked for a local heating contractor serving mostly home furnaces, most were oil fired. I was provided with a new Dodge van, slant six engine with a 3 speed stick transmission and snow tires. We had a lot of snow that winter. I've never driven a 2 wheel rear axel vehicle go in snow like that one did.
Dusty
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12246 |
Posted: 28 Jan 2019 at 8:51am |
1991, owned a 1990 Ford Probe GT, fat sport tires. Sweet car. Was on a job sight. Slight grassy grade down to the equipment. Lots of stuff to carry, so I drove down to it. Worked all morning, lunch time came and I drove off to lunch, no worries. Boss says dang son, if you're working on that mess down there, take the company Suburban to carry all the crap. OK. Damn thing wouldn't go up that grassy grade no matter what I tried! Sorry Shameless, back to even territory and then some!
klinemar
Posted: 28 Jan 2019 at 9:23am |
1978 GMC 1ton 4x4 with 350 engine limited slip 4.56 axle . Could pull anything with 2 ends. Go anywhere but by a gas Station ! Probably the best truck I ever owned and cost $6,000 new!
CTuckerNWIL
Posted: 28 Jan 2019 at 11:54am |
I bought my brothers old 2001 Ferd Ranger about 4 years ago. He got a good used maybe 2008 F150 4x4. He gets stuck in 10 inches of snow in a corn field and the Ranger will go about anywhere but around a corner in 4 wheel drive. He's not very happy about it.
I used to ride to work with a fellow that bought a new 1978 F150 4x4 with a 300-6 and limited slip front diff and a traction lock rear. He ordered it that way. Not many pay any mind to what diff a truck has when they buy em, it seems. That thing didn't like turning in 4 wheel drive either, but would go thru some deep crap when needed. |
shameless dude
Posted: 28 Jan 2019 at 12:20pm |
the biggest thing now a days is that most people won't buy mud/snow tires. they think they can do both with the advertised "all season" tires. all they are...are street tread with the tread just a wee bit spaced, not enough.
Walker
Posted: 28 Jan 2019 at 12:45pm |
Gotta hand it to the Amish, don't pay no road tx then braze crushed carbide to the front of their horses shoes and go do more damage to a road than a fleet of cars.
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 28 Jan 2019 at 1:06pm |
That's religious freedom.
Brian Jasper co. Ia
Posted: 28 Jan 2019 at 3:21pm |
You can add a locking differential fairly easily to the existing axle. There's a type sometimes called a 'lunch box locker' made by Auburn Gear called the Max Lock. It installs inside the original carrier, you just pull the side and pinion gears out. There's no setup or special tools required. It's a bunch easier to do than replacing a complete axle assy that probably needs new clutch plates as well. It behaves like a Detroit Locker so sometimes it will clunk on turns.
Page 12> |
