Poor Man’s……….
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Poor Man’s……….
    Posted: 5 hours 23 minutes ago at 2:51pm
car washing detergent?
The 1991 F-350 has taken a beating from the AZ and TX sun, although it is white the ‘shine’ appears to quite dull, almost a ‘flat white’ look. What would a good household cleaner that may help, TIA.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 10 minutes ago at 6:04pm
Be happy it isn't rust brown or gone altogether and the same color as the background on the other side, like they all are here.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 7 minutes ago at 6:07pm
Most people likely to say you should never use household cleaners on vehicles. Too harsh on the paint. That said, when we was kids, Dad had us wash the car with Cheer laundry soap. It was a powder and kinda gritty. Cleaned real well
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 2 minutes ago at 6:12pm
dont think the type of soap is gong to make any difference... Probably needs to be POLISHED to get the DULL HAZE off... then a good coat of WAX..... if REAL bad, you start with rubbing compound , but i would try the POLISH and see how well it removes the  oxide surface..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 58 minutes ago at 6:16pm
What Is a Rubbing Compound?
A rubbing compound is a gritty substance that levels the paint on a car’s surface. Think of it as fine sandpaper in a paste form designed to remove the outermost layer of paint. Rubbing compound comes in handy when dealing with scratches, oxidation, and other surface defects that affect the outer layer of the car’s clear coat. It’s more abrasive than its polishing counterpart, making it the go-to choice for correcting significant imperfections in a car’s paint job.
What Are Polishing Compounds?
Conversely, polishing compounds are less abrasive and aim to bring out the car’s natural shine after dealing with its imperfections. Their primary purpose is to smooth out the finer marks that a rubbing compound might leave behind. A polishing compound works to refine the work of the rubbing compound, enhancing the paint’s luster and creating a glossy finish. It’s the final touch in the detailing process, helping vehicles look their best before hitting the showroom floor or returning to a customer.
Differences Between the Two
The difference between rubbing and polishing compounds lies mainly in their level of abrasiveness and intended purpose. A rubbing compound acts as a corrector, while a polishing compound serves as a finisher. Rubbing compounds will eliminate deep scratches and oxidation, but they can leave swirl marks or micro-scratches due to their abrasive nature. That’s where polishing compounds come into play, removing those finer imperfections and giving the car a mirror-like finish.
