Polaris atv troubles
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: Polaris atv troubles
    Posted: 27 May 2024 at 3:45pm
I was asked to look at a 500 sportsman atv.
At first or wouldn't start or turn over. New starter and battery fixed that. Old starter drew a huge amount of current and barely rolled over. Battery was 5 years old no longer took charge.
Finally got it to run and noticed it wouldn't charge. New regulator fixed that.
About a week ago I finally got it to start. I had to blow air into the gas tank. Almost like it lost it's prime. Once it started it run good. Shut it off half hour later it would start. All day it would keep starting. Left it sit for a couple days and back to square under. Perhaps fuel pump is bad so I put a new one on. That did not seem to help.
If I blow air into the tank it seems to help start it but you still have to crank on it. Also seems to help to put a booster on the battery to help it start.
Any thoughts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 4:11pm
can we assume you're replaced the fuel filter ?
What kind of 'fuel pump' ?
If it's a vacuum style like B&S gas engines, did you replace the vacuum hose from pump to valve cover ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 5:40pm
It is a b&s style vacuum fuel pump. I have not replaced the hose but my vacuum guage goes to negative 20 psi while cranking so that should be good I would think
Fuel filter is new also yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 5:42pm
Am I going to hurt anything by switching to a 5 psi electric pump? Will I over feed the carb you think? The electric I feel is far more reliable then a vacuum pump
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:18pm
back flush the fuel tank in the  on position and on reserve position , then suck the tank dry i a use a vacuumm pot and a pneumatic vacuumm pump  then clean and rebuild the carb and set the choke clearance correct,   also also make sure the stuck throttle switch up on the handle bars is not acting up throttle cable adjusment usually fixes that  if it is acting up it will not start
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:31pm
Hudco... check what on the handle bars? Can you explain that a bit more.
Like I say this will start and run but it starts very hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:44pm
their is a swicth in the throttle control  that cuts the ignition if t gets stuck on full throttlebut iff the throttle cable gets out of adjustment,   no freeplay in the thumb part it has the switch activated  ireally dont know how to explain it very well inside that part . its like when its in front of me then i remember all the pertiicalars
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 10:22pm
Our Polaris Sportsman 400 does not have this I'm aware of. Been all over that machine through the years but about to put it down as the silent chain is skipping over it's engagement teeth, universals are loose in three of four wheel driveshafts, as is the prop shaft.
Been a working unit all it's life and dependable, but just worn out.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 11:09pm
not all the polaris has them  some of the arctic cat stuff has them also   same with the snowmobiles   some have a magnet on the carb proximity swithch if the throttle is off and the swicth  is still made up on the carbs then it wil shut it down same on efi stuff also
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 12:30am
I'm just perplexed why it runs so well when it does run. Just hard to get stater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 6:21am
hmm. any chance the choke is 'wonky' ?
Neighbour has a Cub Cadet with Kohler and when it's 'hard to start', I have to readjust the choke cable....
probably not the cause, but another thing to strike off the list  ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 6:22am
On ours most times if setting overnight, a splash of gasoline onto the air filter element will get it to fire off and good for the many starts through the day afterward but the process needs repeated the next morning. I want to say our has a "Nikki"carburetor and I've replaced the diaphragm in the carburetor top a couple of times over the years to get this repaired and it works for a spell then back to the usual.
Engine runs very well once started.
That's All Folks!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 10:42am
To start my 2000 Polaris 250 xplorer, slightly crack the throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 5:07pm
if carb is above fuel tank, the electric pump can help.... did that on a couple lawn mowers with briggs engine and gas tank below seat.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2024 at 6:09am
“goes to-20 psi”.
No it doesn’t
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2024 at 6:20am
It's probably -20 " of Hg which is about 4 psi.
if it really was -20 psi that's a super vacuum !!
I do have several pressure gauges that read +- psi
This page was generated in 0.170 seconds.
