Plumbing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 6:30am
Might not want to drain it in the sump Dale .All the goodies from the sink drain want to float on top and mess the float up .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 9:09am
Opted to 1/4 turn ball valves when built this house. Positive shut off, nothing compresses, nylon and stainless system less chances for corruption.
So Far, not been a concern changing things downstream.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 10:37am
Four year old post of mine. Wife's having our master bathroom remodeled. Guys couldn't get the lav faucet and toilet supplies to shut off completely. After they left for the day I replaced the 3 shut off washers. No more drips. Maybe this time I'll be smart enough to do every shut off in the house. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 11:53am
AC in SC , problem with any plumbing valve is by the time you need it, it probably won't work. When ever I replace a faucet I replace the shut off valves below them at the same time. Same with a toilet or any other fixtures. Also want to connect a long supply line and run water into a bucket before connecting new faucet. Make sure to flush line out so debris doesn't wash into new faucet.
I try to install lever ball valve on the main water supply and they need replaced about every 20 years. I replace valve above water heaters when I replace them . Customer will ask why until I show them the inside with all the mineral build-up in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2023 at 12:14pm
Thanks Pat! I do flush the lines out . Hopefully new supply stop washers will work another 10 years . I may be past caring by then? Old washers are hard and brittle and fall off when I pull the stem out. Thanks again!
This page was generated in 0.104 seconds.
