plowing with a B, HELP!!! |
Post Reply |
tractorboy
Silver Level Joined: 03 Oct 2009 Location: southern Va Points: 466 |
Posted: 12 Sep 2010 at 11:04pm |
I cant get it in the ground more than 3 inches. I do not have the correct belly hitch, but in the past I just turned the draw bar around {facing forward}. I guess this is the problem since there no adjustments on a b plow , right? In years past it seemed to do fine. I usually have to keep my hand on the hyd. to lift a little while plowing, at times even tapping the left brake to keep it straight. I guess a picture of the under belly hitch- hook-up would help if anyone has that. Or maybe some measurements of how high this hitch point is & side to side also. This piece of ground hasn't been turned over in 20 yr. !!!! Any help greatly appreciated Keith.
ChuckLuedtkeSEWI
Orange Level Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
The front mount which the plow hooks on to pivots off of brackets that mount onto the final drive housings. There is a depth control lever that bolts onto the square tube that your foot rests on which will control the depth of the plow by pivoting the front mount up and down. I don't have any pictures of it, but I hope that explains it. I have a spare front mount and depth control lever here if you're interested in it, but I live in WI. I don't know how bad shipping would be to get the two brackets down to you. Maybe someone closer to you might have them. Without the two brackets, you can't control how far the plow goes down.
Post Reply | |
