Plowing video that would be neat |
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2894 |
Topic: Plowing video that would be neatPosted: 06 Nov 2016 at 6:21pm |
I was reading about the use of number 9 wire on a plow. It would be neat of someone who really knows how to do it would have a video that shows:
1. Where to attach the wires, now long they are etc.. 2. How to get the plow started in the furrows with the wires. And show where the wires are running as the plow plows.. And anything else we need to know! |
DaveWisc.
Posted: 06 Nov 2016 at 7:13pm |
My dad run #9 wire when we plowed, but mostly I remember that it was for plowing under corn stalks not used to much in sod ground. You need to hook this on the coulters and run it 2 feet past the last plow bottom. Make them vary in length as need be. This will help pull trash through the plow bottoms and help it to not plug up. Hope this helps.
Dipstick In
Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
Posted: 06 Nov 2016 at 8:09pm |
It just sounds more complicated than it is!
We never used it in corn stalks,,,,,,,,,, just chest to head high rye.
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Posted: 06 Nov 2016 at 8:25pm |
Plowing down sweet clover we used short pieces of chain to help get the clover covered.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 06 Nov 2016 at 8:27pm |
Chain sounds like it would work better, and be a great way to clean up all the rusty chains hanging around the place!
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Posted: 06 Nov 2016 at 9:24pm |
I'd be interested in seeing how this is done as well.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
allischalmerguy
Posted: 06 Nov 2016 at 10:14pm |
A couple of photos from the web
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12320 |
Posted: 07 Nov 2016 at 6:46am |
Huh! Amazingly simple....hard to believe that accomplishes anything, but I trust you guys that it does. Neat.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8619 |
Posted: 07 Nov 2016 at 6:55am |
Never heard of it before, at least not in this neck of the woods!
Regards, Chris |
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Posted: 07 Nov 2016 at 10:31am |
X2!
'39 Model B
Tractors are cheaper than girls, remember that! |
Butch(OH)
Posted: 07 Nov 2016 at 10:47am |
Back when a neatly plowed field were admired and thing of pride dad would run wires when we were plowing under rye and sometimes corn stalks. The end of the wire drags under the furrow and holds the wire tight and anything sticking up is pulled under the wire and plowed under. It works really well with only minor short comings.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3085 |
Posted: 07 Nov 2016 at 10:59am |
I've never heard of that here in Indiana. So do you have to get off at the beginning of each pass and get your wires all set as you put the plow in the ground?
Butch(OH)
Posted: 07 Nov 2016 at 12:35pm |
No, they pretty much take care of themselves and go where they are supposed to as long as they are on the right side of the bottoms. Occasionally on the snap coupler plows the front one will try to wrap the tractor tire. You do have to be a bit careful how you turn but they are not a problem child, they just do their jobs without much fuss.
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2677 |
Posted: 07 Nov 2016 at 12:36pm |
No you don't have to do anything, as stated before, the dirt turning over pulls and holds the wires down therefore pulling the top of the grass down. Also, after running the wires for a while be careful as the ends will have a sharp point on them.
