Plow
Bcjk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bcjk Quote  Post ReplyReply Direct Link To This Post Topic: Plow
    Posted: 27 Mar 2012 at 3:45am
Just bought a 83 series snap coupler plow very good shape solid bottoms. It doesn't,t have a gauge wheel and wondering if that is a must? Going to pull it with a series 11 D-17 and just plan on using wheel weights and no fluid in tires, soil is fairly heavy. Hope to get photo bucket down loaded to show my project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 8:30am
If you have a long landslide on the back bottom it doesn't need a gauge wheel. The long landslide controls the depth and is adjustable.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 8:42am
As long as it has a long landside on the rear bottom with a properly adjusted slip heel, it should be fine.  The gauge wheel option just makes adjustments a little easier and there are less wear parts to buy.
Bcjk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bcjk Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 9:12pm
Thanks! It does have both ,solid bottoms with trash covers on top of the mold boards .Will a D17 pull a three bottom up here in north Iowa with just wheel weights and no fluid!
