Plow identification
bbcm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbcm Quote  Post ReplyReply Direct Link To This Post Topic: Plow identification
    Posted: 13 Apr 2016 at 12:34pm
Can anyone tell me what type/year our plow is?
bbcm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbcm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 12:36pm
bbcm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbcm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 12:37pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 2:39pm
Not in my plow book.
Gerald J.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 2:58pm
It's the plow that came with the WD before snap coupler. This one has been converted to the snap coupler eye. Can't tell you the model but there aren't a lot of them around.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 3:19pm
I think it's called a WD Pickup Plow and it has the WD drawbar still stuck in it. I believe the drawbar usually stays with the tractor.
I guess it's a 45 drawbar that is stuck in it but it can be used either with the pin type drawbar of the WD or the Snap Coupler drawbar of the 45.
Edited by Lonn - 13 Apr 2016 at 3:20pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 3:29pm
Yes it is a WD Pick Up Plow. I wouldn't use that with a snap Couple set up without running a chain under the drawbar to keep it from flipping up if the bell disconnects. That plow was made to bolt to the WD pin hitch drawbar. The connections on the lift arms won't let go like the Snap Couple lift latches do if the plow come loose underneath and it will dig in at the front and flip up driving the seat and operator into the steering wheel.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 3:01am
Amen to that. It is very scary (afterwards, you don't have time to be scared while its happening) to be plowing along and all of a sudden the tractor picks up speed, a strange noise from underneath and then you realize the lift latches are releasing; all while you are trying to hit both the brakes or at least one of the clutches and close the throttle all at the same time.
Add to that trying to get out of the way of the plow so it doesn't kill you if the lift latches don't let go properly.
Actually it probably takes more time to read the two paragraphs above than for it to happen in real life.
If you use a chain as a back up safety, I would either bolt it in place, or mouse the hooks with wire so it can't come loose. Remember Murphy's Law.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:46pm
Robert
This WD didn't have the lift latch update, just the SC bell so the lift links were pinned on Ouch
