plastic hugger snout points
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: plastic hugger snout points
    Posted: 27 Nov 2024 at 8:30pm
Anyone know if the points are cast steel or cast iron? Could plate them if they can be welded on. $50 bucks + -
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2024 at 8:57am
If I had to guess id say they are steel. Strike an arc with a 7018 rod and you will know pretty quick
If the weld lays dowm they are steel. If it bubbles up they are cast
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 8:58am
Yes they are cast.
ryan
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 11:27am
Shoup catalog has them, new also.
Leon B
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2024 at 10:05pm
I braised welded one back together years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 9:32am
Originally posted by ryan(IN) ryan(IN) wrote:
Yes they are cast.
I can see they are a casting. The question was cast what? Iron or steel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 10:44am
The note in my system at work says cast point for steel use 71364963V. But that part number supersedes back to 71364963 without the v that just says cast point. I’d assume cast iron.
ryan
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 2:54pm
I welded AR steel plates on the bottom of a set of mine on a steel snout hugger head.  I used ER70SD4 wire in my MIG, they"re still on the head today
This page was generated in 0.104 seconds.
