Planting Sunflowers |
dink
Topic: Planting SunflowersPosted: 02 Apr 2017 at 8:58am |
I have AC 72 unit planter. I'm wanting to plant sunflowers. Does a corn plate work on sunflowers? Thanks
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2319 |
Posted: 02 Apr 2017 at 10:18am |
No, you will need different plates but the seed dealer should be able to get them for you.
clarkscreek
Bronze Level Access
Posted: 02 Apr 2017 at 10:22am |
I don't if the plates you have will work, never did sunflowers but I had an allis planter with the adapters to use jd plastic plates. I was able to plant quite a few different garden crops by just trying different plates until I found some that were acceptable. Not exact or picket fence rows but good enough.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Posted: 02 Apr 2017 at 11:46am |
Can you find a neighbor to custom plant with a Deere finger pick up? Had pretty decent success with flowers planted by a Deere.
jiminnd
Posted: 02 Apr 2017 at 12:10pm |
Usually have a filler plate and then the seed plate, seeds are thinner than corn, I suppose if you are not planting alot and not too fussy about population you maybe able to make it work but would have a job figuring out planting rate. Plates are pretty cheap compared to seed costs and a poor stand.
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Posted: 02 Apr 2017 at 7:47pm |
I plant sunflowers mixed with corn seed for food plots with my 495 John Deere planter, have had no problems since I've started doing this. Going to try straight sunflowers this year. As long as the seeds fit in the slot of the plate you should be fine. I pick a plate that fits the seed well and then throw a handful of seed in the hopper and turn the plate by hand to make sure the seeds feed into the slots and not get ground up by the plate. I plant soybeans with corn plates in the same fashion and have had no problems.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 03 Apr 2017 at 7:29pm |
planted about 1/2 acre of sunflowers and 8 long rows of sweet corn for my honey bees.....
