Planting Corn
Brad VB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad VB Quote  Post ReplyReply Direct Link To This Post Topic: Planting Corn
    Posted: 01 May 2010 at 10:00pm
Spring planting in South Dakota
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 10:08pm
Looks good. Too wet here in the NE.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 6:55am
I'm weighting on some sunshine here in west central MO. maybe by Friday I can put some corn in the ground too. I start getting antsy about this time of the year. lol
Don
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2010 at 11:41am
Nice rig! What size planter 12 row? what size tractor on the front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad VB Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 7:02am
8010 with 12/30 6100 white
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 9:11pm
Does the 8010  have enough hp when you are pulling that planter in no-till? looks like you have the traction side covered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad VB Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 10:31pm
low 5th about 2000 rpm works well
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 10:40pm
you can't plant...standing behind the planter!!!  I plant 6-row 30" now, but when i used my 8-row wide, it was a 3-pt mounted 8-row ac, on my 180, then had 600 gallon saddle tanks mounted on the 180. worked great, pulled in 3rd gear about 1800 rpm's. now i don't spray anything at planting.
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:15am
Looks like you don't need much h.p. in that flat ground! Come here to central Ky. with that rig on our rolling hills and red clay. Great picture!
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 7:16pm
Done planting April 21st. The floods this past weekend revised that to 1/2 done.
Gorgeous 8010 you have there!
There isn't much a WC can't do.
WD's just do it better.
