Planter plates |
SD Allis
Topic: Planter platesPosted: 04 Apr 2018 at 3:35pm |
I am in search of a set of 4 planter plates, #310922
Thanks In Advance Warren |
DanD
Posted: 04 Apr 2018 at 11:04pm |
Is this just a normal corn plate? If so just get the adapters and use JD plastic plates that you can find easily.
Edited by DanD - 04 Apr 2018 at 11:05pm |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 05 Apr 2018 at 7:04am |
Bean plates
DanD
Posted: 05 Apr 2018 at 9:42am |
https://goo.gl/images/UnsgLK
You need a set of these...then get JD plastic plates. Available from places the sell plates like Lincoln. Edited by DanD - 05 Apr 2018 at 9:43am |
DanD
Posted: 05 Apr 2018 at 9:47am |
SD Allis
Posted: 06 Apr 2018 at 1:27pm |
Yes there are beam plates
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 06 Apr 2018 at 2:42pm |
Just a warning - these were the old 70310992 bean plates designed for the old Hood type huge soybean seed. They are not acceptable with todays small soybean seed. In order to get the desired seed rate one has to have the largest sprocket available on the front and the smallest on the back.... This turns the seed disc so small it 'hill drops' the seed then skips then again plants 4-6 beans in a short space. As suggested use the soyb 2 or soyb3 for 15" rows and the adaptors of course..
