Planter boxes
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Topic: Planter boxes
    Posted: 26 Oct 2022 at 6:40pm
Will the old round metal boxes work in place of the white plastic ones or is the planting mechanism different on the plastic boxes.....maybe something changed because the plastic ones are later model planters.
The planter they will be used on is the row units that drive off the press wheel.
Planter is old enough it has flat chain links instead of roller chain on the drive units. The planter that I saw the metal cans on at the salvage yard appeared to be basically the same type of row units (driven with the flat chain) but I didn't know if the plates and planting mechanisms were the same.
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2022 at 11:46pm
Yes they will work
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2022 at 11:34am
Thank you Sherman Farms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2022 at 10:11pm
I also replaced my round plastic boxes with the newer square boxes (fiberglass) on my 600 planter
This page was generated in 0.953 seconds.
