Plain Old Victor Mouse Traps ? |
BuckSkin ![]() Orange Level ![]() Joined: 12 Sep 2019 Location: Poor Farm Points: 972 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Sep 2025 at 2:17am |
Maybe I am missing something and obviously don't know what I am doing.
I have baited countless plain old ordinary Victor Mouse Traps; the kind with the Copper bait holder/trigger thingie. I have successfully caught thousands of mice with these traps. However, for the last several years, as delivered, where the cheese goes is a tightly rolled and clinched together toothed business that is useless for attaching any kind of bait that I know of. I have to firmly hold the Copper thingie while I force the point of a 1/4-inch Wood Chisel in under the rolled crimped toothed thingie and raise/straighten it into a wider-mouthed "U" shape where I press in my cheese. Once I overhaul them, they work fine = hair-triggered and deadly = so sensitive that my heart-beat will set them off while I am trying to place them. Is there good reason for the traps to be made as they are ? Am I the only human alive who doesn't know the trick and am resorting to re-working them so I can use them ? For me, my way works, whereas the as-delivered is worthless.
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5100 |
Congratulations buckskin! You're officially building a better mouse trap!
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13725 |
Hey Buckskin,,,,When I DO need some,,I still buy those wooded traps ans Yes,,I do need to " Adjust " the bait part to open it up a tad. Mayhaps,,they know someting that we ain't figured out yet,,,??
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6483 |
I have to open mine up a bit. And the peanut butter works good. In areas where other animals can’t get at it I put out some mouse candy, green blocks work on mice but I need the yellow blocks for rats.
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1936 |
The ones we have now have a little yellow plastic paddle with some small holes in it. You just put a dab of peanut butter on. I see on the internet the ones with the roll your suppose to put the cotton from the top of a cotton swab in it and the mice want that for their nest material.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12218 |
Haven’t paid attention to that, have been using peanut butter for decades.
Well, that sure is a new one on me; never in a million years would I have thought of using nest material as bait. I had a bunch of those traps with the yellow plastic paddle and didn't like them as they were not sensitive enough and no way to make them more so that I could figure out. The ones we had, you actually weren't supposed to need to bait them as that yellow paddle was impregnated with "cheese smell"; --- I always added real bait to them anyway; however, I did have one that I set without any added bait, just to see if there was anything to that "no need to bait" business; that thing stayed set in the shop for years without anything showing any interest in it; and, then, after being there unmolested for ages, it caught a mouse. I used to swear by peanut butter as the best mouse bait one could use; but, the last few years around here, these mice seem to much prefer cheese. I can have a trap set with peanut butter for weeks and not get thrown; I can set another right beside it baited with cheese and have one caught within hours. I will say this, the peanut butter is a lot easier to use.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54243 |
Bacon bits work wonders, sometimes...
![]() Maybe the chinese mice are smaller, so that's why the bait thingie is smaller...
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2681 |
Rats and mice generally run along the base of walls. Put the trap perpendicular to the wall with the trigger end against the wall. The mouse will run over the trap, trigger it and you get a shot at the mouse's entire body. No bait needed. Try it.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42000 |
I got overrun with mice here over the winter and up to a few weeks back
Went through over 20 pounds of TOM CAT green mouse blocks Had a bucket setting on a chair out in shop , had left the cover off the 8 lb pail 3 dead mice in bucket , lot of droppings , and about 3 pounds of blocks gone By house 8 pounds in 2 weeks , another 2 pounds out by trees where i seen some holes at base . I took some 2 pound plastic coffee cans , drilled 2 holes in them with 3/4 hole saw , then ran 2 pole barn spikes up through bottom to place bait chunks on , put some pea gravel in bottom to weigh them down - have to preplace the 4 blocks about every 4 days Bought some yellow Just One Bite blocks - some eaten but not as much as small Tom Cat blocks . I have 5 of the plastic cans now set around house , going to make up a bunch more to place in and around shop . Son had some outfit spray around house and yard for ticks and mosquitoes and they put out to bait stations but never cam back to service them as am sure bait was gone in a week .Just have to figure out what tool opens them Have a bait station that holds 12 of the Tom Cat blocks and that gets emptied fast also . On the Victor traps the liquid mouse bait works well , have got more with that inside house and garage than other bait . Have a couple of the see through mouse catching traps 6 x 12 or so galvanized metal box with hole on ends . Problem is live mice - to dispose of them drowning is only way to clear trap without mice running ever where when opened |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25206 |
I feel your pain! The ones I could find had plastic bait tray/trigger. would not hild the cheese. Switched to cheap peanut butter. works like a champ!
I am still confident of this;
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8955 |
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 467 |
I just wedge a peanut piece from crunchy peanut butter in that loop. The victor Tin Cat works too. Vintage mousetrap channel with a repeater trap too. https://m.youtube.com/@ShawnWoods-Homestead . |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4099 |
I use butter for bait, the real stuff not margarine. Seems to work better for me than peanut butter. Have tom cat and various other blocks out in the buildings too. Anything to keep the population as low as possible! What I hate is when the stupid coons start eating the mouse poison. It does kill them, in time. Expensive way to be rid of them though. In the summertime the darn crickets eat any and all mouse bait! They absolutely love the light green tom cat blocks. Catch a mouse in a trap and they start eating them too. Nasty little buggers!
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 442 |
I drill a small hole in a kernel of field corn then using thin wire I wire it to the trigger on the mouse trap. Works great, and get several kills on the trap before having to refill it unless his buddy comes and cleans it off
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1331 |
I have had success using a raisin stuffed into the bait crevice, one raisin will often last to catch several mice.
