Pitman arm for B/C Sickle Mower
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Topic: Pitman arm for B/C Sickle Mower
    Posted: 30 Jun 2010 at 12:16pm
I need the dimensions for the Pitman arm so I can make a couple for my broken ones. Could someone measure one for me please?
TIA
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:08am
Bump, still need this please!
Miles Gray (CO/KS)
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:11pm
Miles:
It is important to know what style pitman you have.  The early style used a ball swivel that clamped over the knife head ball with a bolt, nut, and leaf spring setup, while the later style used a coil spring that fit in the end of the pitman to hold the swivel halves tight on the knife head.  The early style is the simplest, and you could probably work out the correct length with some careful measurements of your mower, and after that it wouldn't be hard to make up a pitman that would work just fine.  The later style might be more sensitive...
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 7:16pm
I'll try and remember to measure mine tomorrow
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:25pm
This is the type of sickle mower I have, it does not have the bearings on the ends.
7 foot mower.
Thanks, Miles
Edited by MilesGray (CO/KS) - 07 Jul 2010 at 8:30pm
Miles Gray (CO/KS)
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:33pm
Miles,
Have a look at http://www.oldengine.org/members/steinich/ click on the Pitman Pictures link.
Dave
Roger Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Mn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 8:49pm
You can buy them at tractor supply Roger Mn
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 9:45pm
Miles:
I'm confused by your reply.  Do you mean that you have none of the hardware that bolts to the wooden stick, or do you mean to say that you don't have a twin wheel drive mower that uses ball bearings in the pitman?  Here are pictures of the early and late style pitmans that used wooden sticks:
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2010 at 10:13pm
 Looks like all you need is the wood pitman blank tractor Supply has them T S C  stock number is 1206405
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 8:25am
Thank you all for your responses, I do have all the parts just not the wooden pitman arm.
Miles
Edited by MilesGray (CO/KS) - 09 Jul 2010 at 8:27am
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2010 at 9:47am
Sorry for the delay.
Mine is 26" long x 1 1/8" x 1 3/8"
Charlie
