Piston scoring D-21/210/220/7030 engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:29am
Thank you, David. Here are two pictures of the current 220 I'm working on. The 1/2" belts are bottomed in their grooves causing fan speed reduction and lower coolant flow which can lead to possible over heating on a warm day at 100% load. The alternator charging at 100% output can also have belt slipping issues. Changing to "B" width belts pretty much solves the slippage problem and especially on 50 year old pulleys. Another problem we have here is someone (not very knowledgeable) in the past has installed a fan spacer that moves the fan forward to within an inch of the radiator. This makes it impossible to work on and air flow is actually reduced, causing more potential engine over heating. This change may have been an effort to combat an over heating engine on a hot day?? One might think moving the fan closer to the radiator core would draw more air thru the radiator, but the reality is that's not the case. Max air flow is achieved when the tips of the fan blades are 50% in and 50% out of the shrouds edge.
Edited by DrAllis - Yesterday at 7:20am
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 6 minutes ago at 9:29pm
Yes DrAllis. One fan tip may even have a slight opposite bend to assist that science?
A “Centrifugal effect” of airflow is created from rotating fan blades that forces air toward their fan blade tips, where air is then forced along 1” clearance of shroud which allows air to be pushed outward from shroud edges for a more rapid exit. It creates a good constant vacuum where minimal air has no/little chance to recirculate back inward.
This page was generated in 0.135 seconds.
