Piston scoring D-21/210/220/7030 engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: Piston scoring D-21/210/220/7030 engines
    Posted: 27 Nov 2025 at 9:09pm
Trying to finish up this customers knocking 220 engine. I've experienced this problem for I'd say 30 years off and on. It's always the engines that don't have piston cooling spraying oil from underneath to keep piston temps down that seem to do this. Replacement pistons and sleeves are parts that work fine in 7040's and bigger because they do have piston cooling, but the newer design piston/sleeves do not like being used in the old non-piston cooled engines. Unfortunately, the old piston/sleeve parts have been discontinued for a very looong time.  All you can purchase now is the newer designed tighter fitting parts.  The older engines used to spec piston skirt to cylinder sleeve clearance at .007". All the newer piston/sleeve kits are .003".  Sometimes they work for years and then, just like this engine, you've got a mess to deal with. I've got a jig made to take my sleeves to a favorite machine shop and have (new or old) sleeves power honed out an extra .004" to alleviate this problem. It's an unfortunate event with no warning whatsoever. My advice is if you are overhauling one of these older non-piston cooled engines, you'd better loosen it up a little or you might get to do it again someday down the road. Pictures on the way.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2025 at 4:40pm
Thanks DR. I've heard of this before. Had this happen about 20 years ago while breaking in a fresh rebuilt D21 engine on the dyno at a moderate load.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2025 at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2025 at 11:39pm
I got the 220 engine fired up today and it sounds fine, but was only ran for a couple of minutes as it was supper time. This engine has the later model crankshaft driven oil pump and deeper oil pan on it. The oil capacity should be 21 quarts. This tractor has passed thru how many owners and technicians over the years ?? Who knows ?? Anyway, there isn't a serial number tag on the engine block, so I'll have to try and determine by the chassis s/n if it had this newer oil pump or not from the factory. I did notice that the engine oil level dipstick had been modified by someone in the past. It has been made longer, which would cause you to NOT fill the engine to 21 quarts capacity. I think it's about an inch too long, so we've probably been maybe 2 gallons LOW on oil all these years??  So, I will be changing that for sure. It also (at some point) had new slotted -.010" rod bearing shells installed and they did not get the connecting rods turned around as was required with that change to updated parts. So, now that has been corrected. It now has the newest "ARP" brand connecting rod bolts installed and torqued to 85 ft lbs. All six new wrist pin bushings were needed as they should have been replaced when the engine was OH'd before sometime in its past. One more thing to be extremely careful of when installing sleeves in these engines. Obviously, you want to clean the block very well and dry fit the new sleeves without the Orings on them. They should go in easily and be able to rotate when installed fully in the block. Remove the sleeves, roll on the new Orings (two black on the top two grooves and orange in the bottom groove) and then with a pocket screwdriver go around each one to be sure nothing is rolled/twisted. Now, the next important part: wipe Mazola cooking oil lightly on each Oring with your finger. Also wipe the inside of the lower block bore too. Nothing excessive !! just a light coat on the rubber and in the block bore. Shove the sleeves in and bolt them down. Excessive lube between those Orings can cause things to squeeze the sleeve and when you've only got .003" skirt clearance, you cannot afford to have that happen. Maybe the snow storm won't be so bad tonite and I can get the front axle under it and get in a hr or so of run time tomorrow. We'll see !!
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 12:08am
I'm sure it wouldn't help if it was turned up some. Show me one that isn't. Mine got the mains jetted at OH with M&W's and turned to 170hp in early 2000's. Has around 1500hrs on it. So far so good. It's retired to batwing duty now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 12:47am
I've thought of a couple of other things too that could contribute to this problem : A muffler versus a straight pipe. A straight pipe might be enough of a benefit (100 degrees pyro temp cooler ) to offset altering HP upwards a bit. The fan belts on the D-21/210/220 were those da** shoestring width sized belts that had to be kept very tight or there was a reduction in fan/water pump speed at full throttle, especially when the tin pulley on the fan got worn. It makes sense that 180 degree coolant temps would have to be better than running right on the edge of the red when it comes to piston skirt diameters. Lastly, your M & W's probably are a little looser fit than .003".  For sure there's less blow-by with their top ring design and that would make for a cooler piston too, wouldn't ya think ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 7:34am
This should be put in knowledge section
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 10:32am
Do you think that the scoring starts around the o-ring area? Our shop worked on an early 7030 one time that would score the pistons on a break in pull on the dyno. I didn't personally work on it and I remember that it was turned up to 180 horsepower. I think that it did that twice before we talked to someone higher up and they suggested removing the top o-ring on the sleeve. My memory fades, but I think that fixed it.   Question, were the 426 engines always a three o-ring design or did the early ones just use two on the sleeves?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 11:14am
I'm for sure following this thread, because I have a 220 that needs a complete rebuild. needs an injection pump rebuild also,,planning on turning it +12-15%,, jus for playing mostly,, as long as I have it,, it will never see long days of hard work
Hey DR.,, is there a way to get a sleeve/piston/overhaul set from you that has been honed the +.004??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 11:24am
Old original Gen One 426's I know were only two Orings. One black on top and one orange on the bottom just like the 301. You find that out on the first OH. Personally, I've only ever seen three Oring replacement sleeves and I'm sure a 7030 probably was just that. Remember, the 7030 engine developed 12 to 15 more flywheel HP right off the bat compared to a 220 engine, because of chassis/hydraulic loads. I too know of a very early 7030 that went thru two OH's in the first 24 to 36 months of its life due to scored pistons. It had an intercooler installed and turned up a bit. I don't remember if the muffler was on it or not. I didn't work on it either time but was aware of its issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2025 at 11:30am
That could be done. Or you could get your own kit of choice and just send me six sleeves and one piston and I can have them oversized for you. I'd suggest checking the clearance first to verify they are in that .003" to .0035" range to warrant doing it. My guy charged me $50 bucks each I believe.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 8:17am
Update to this subject:  This particular 220 tractor got finished and driven 30 miles home on a nice Saturday (I think) the week after Thanksgiving. All is well at this point. Ten days ago, I had another 220 brought to me with a slight knock in the engine and coolant in the oil. I feel pretty strongly that we have another scored piston scenario with it too. I don't know the history on the tractor or engine, but maybe in a couple of weeks I'll have a chance to get into it to verify my suspicions as to what's actually going on.  Finally, on the same subject, last night a friend of mine called me and was telling me of a restored 220 in his neighborhood that has right at 500 hrs on an engine OH that was being used on a forage chopper and now suddenly has coolant in the oil.  It has since been parked for some time because of this.  The owner thinks that an Oring was cut when a new sleeve was installed. I am wagering, once again, tight skirt pistons and sleeves and maybe some warm operating temps and once again, a scored piston or maybe more than one. In 50 years, I've never seen a cut sleeve O-ring at OH time, as there are three Orings to cut.  But I sure have seen scored pistons that fry the sleeve Orings and dump coolant in the oil. I don't know if I'll get that engine to repair or not, but we will see how things go.
Edited by DrAllis - 15 Jan 2026 at 8:19am
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:10am
The guy who OH'd my 220 warned me to let engine get up to temp before loading it or it could experience "4 corner score". Have no idea what clearance the M&W's were made with. He worked at a Deere dealership in the early days and said they experienced this problem on new 4020's when dynoing them before delivery. Must be something to it.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:37am
I suppose that could be the aluminum piston was growing fatter and faster than the sleeve was until up to full operating temps.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 12:22pm
When we have them down we usually plug the oil squirter hole for the old cam driven oil pump gear that is not now used. In theory will up cold start oil pressure on the galley it feeds.
Doc- as to those belts, I use a wrap idler bolted to the pump front cover off an F2 to push the belts in and wrap the water pump pulley more. EZ to install. 71178651 is the pulley needed.  It is designed for matched belts, flat sided.  Have done the ones I own. Doubles the belt life and don't have to run them as tight. Doesn't 100% cure the issue but really helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 12:35pm
So, you're pushing in on the fan belts on the injection pump side ?? That would certainly help with belt pull power.  I've got a couple that I have gone so far as to use two "B" width belts, especially for that worn tin water pump pulley. They stand up high, but when tensioned properly they do not slip.  Same thing on any D-15 that I work on. A new 1/2" wide belt instead of the original 3/8" one.
Edited by DrAllis - 10 hours 50 minutes ago at 4:50pm
tadams(OH) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 2:13pm
Used to have this trouble in semi with Cummins if you didn't leave them warm up before you headed down the road usaually happen in the winter
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2026 at 9:18pm
Yes, and would probably help if added a 1/2" longer belt and moved it in even more. Wrapping the worn water pump pulley  helps, alternator still slips after long cold starts as it charges wide open.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 12:45pm
Tim. Where are you putting the pulley
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 4:58pm
Right on the front injection pump cover plate - use one of the bolts - longer of course - and shims. I will try to get a picture posted.  EZ to do. I made a big mistake and put a 6 blade fan on one (210) - 2 shoestrings as Doc calls them just will not pull it at 2400 RPM for long.  I got off the tractor after the first joy ride and was covered with belt chards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 5:57pm
I had a good day today at the shop. Got the front axle rolled out from underneath 220 #two and removed the pan. I can see coolant dripping from the #1 sleeve and the piston is scored too. I also see scoring on piston #5.   So, I need to get some help hoisting that 200 lb hood up and off and begin the tear down to see how many more pistons are scored. This tractor has an incorrect radiator fan spacer about 2 inches thick, moving the fan forward into the shroud box, thus reducing the maximum possible air flow. The fan blades are dinged up and it has 1/2" AGCO fan belts that are bottomed out in the fan pulley and the alternator pulley. I'm thinking this one really got hot some time recently from poor fan placement and slipping fan belts at full throttle. Chassis s/n 220-1267 and engine 3D-10390. It has the old camshaft driven oil pump.
Edited by DrAllis - 07 Feb 2026 at 5:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 11:47pm
Them hoods are rediculus! Must be 11 ga. Appear as 1/8 in. Bad job with 2 people.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 41 minutes ago at 7:59am
Many years ago, I built a rolling "A" frame with a 1 ton electric hoist on the beam. Best shop tool ever. Works great lifting those 220 hoods and many more things.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 7 minutes ago at 9:33pm
30+ years ago I lifted the hoods off 190's by myself. Now I have used the cherry picker fully extended to lift them off from the front. It might work from the side if you have room and can negotiate the tires. Last couple times I drove in the machine shed under a truss and threw 2 ropes over the truss and hoist them off that way. Just need something to tie them off to to hold it up.
