Piston question
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Topic: Piston question
    Posted: 25 Jan 2014 at 9:24pm
I'm looking to buy 4.125 high comp. flat top pistons for a 170. I'd like to find a kit with all the gaskets and bearings. Where is the best place to buy them at. Not having much luck with finding any, thanks. Zeb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2014 at 7:40pm
Zeb - look at the top right page and click [Parts, etc.].   Look for Jim Danforth/OK Tractor - I know he sells the 4 1/8 hi-comp kits.  Be sure though that the exact compression ratio is documented by the manufacturer before you buy.  Standard 4 1/8 kits are usually only 6.5:1 (WD45 style).   I look at Jim's kits a couple years ago but then we couldn't get a straight answer from the maker on the CR (suspect it was 8:1) so I went with a 4" AGCO 175 kit (8.25:1) for my D17.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
This page was generated in 0.058 seconds.
