pipe for trailer ramp's
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Topic: pipe for trailer ramp's
    Posted: 27 Aug 2022 at 12:24pm
I have a 14 K deck over trailer. The pipe is bent that crosses the back of the trailer holding the foldup ramp's. Should I just buy a steel pipe to replace it? or do I need to buy something special ? The other thing is the beaver tails getting rotted I was wondering about replaceing it with steel angle iron instead of treated lumber. Whats everyones thoughts
thendrix View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 12:31pm
I believe the ramp pipe on our trailer is plain old 2" schedule 40 pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 12:54pm
do you have a center support, or does the pipe just support at both ends ?  Center bracket or some stabalizer helps with the load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 12:57pm
nothing wrong with angle iron on the tail... helps get some grip when loading.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 4:28pm
On my tri-axle tag trailer for hauling crawler and backhoe I used angle iron welded to frame members on the beaver tail . It had a good part in allowing no slip when loading as well as allowing any trapped material to fall off when loading .
 For loading in winter stopped any slipping from ice or snow caught on deck or tracks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 9:24pm
yes it has a flange that the pipe runs through on both sides and the center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2022 at 9:33pm
Normal PIPE that you get from the Hardware store will be schedule 40 ... If you have a steel Supplier near you, you could get a schedule 80 pipe ( thicker wall) and be stronger..
What is the difference between Sch 40 and Sch 80 pipe?
The major difference between schedule 40 and schedule 80 pipe is the wall thickness, inside diameter, and their weight. Schedule 80 will have a greater wall thickness, a smaller inside diameter and a higher weight than Schedule 40 pipe at a given nominal pipe size.
Edited by steve(ill) - 27 Aug 2022 at 9:34pm
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2022 at 11:47pm
Originally posted by Brian S(NY) Brian S(NY) wrote:
I have a 14 K deck over trailer. The pipe is bent that crosses the back of the trailer holding the foldup ramp's.DIV]
Road salt rust-probably? Loading ramps each have perpendicular & horizontal frame supports under each ramp~Maybe, maybe not? If not, then during loading of equipment, it’s weight bridges too far & helps bend dovetail’s ramp pipe, which is probably half way ~ weakest point??
Try installing 1/4” wall steel black pipe. And if needed, add ramp supports. Got any photos?
Edited by AC7060IL - 28 Aug 2022 at 11:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 6:06am
pipe is hollow.roadsalty water gets inside,weakens/rusts the pipe over the years.
you could replace with a  SOLID BAR, but it'll give you two hernias and empty your bank account !
as other have said, use a sked80 pipe but.. weld ends on plug it and add 2-3-4 1/8" holes along the rear edge. Use these to spray a LOT of rustchek,oil, or similar. when done, dab some caulking to plug the hole ,or just leave them.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 9:57am
The trailer we have at work with ramps is a solid pipe that the ramps pivot on.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 11:54am
No such thing as a solid pipe. WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 12:48pm
Sometimes words are hard. Solid shaft is what I meant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 1:02pm
Most that i have seen that are BENT are not rusted.... The  ramps have been overloaded and bent the pipe or damaged the center bracket that supports the pipe / bar.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 1:25pm
When I built the dovetail onto the back of this flatbed single drop trailer I used "drill stem" steel for the ramps to rotate around on. This was 1983. I just snapped the photo as pulled the trailer out to finish up the rebuild of the same dovetail citing rust eating the xmembers away. Those "hinges" have never bent on me as the wall is 11/16" thick.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2022 at 2:33pm
Old photos of the trailer before I cut it apart to make repairs:
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2022 at 10:34pm
For the ramp hinges on one of my dove tail trailers I used old hydraulic cylinder rods that I had around the shop that had the chrome flaked off from a previous equipment repair.
