Pioneer fitting couplers Allis 6080
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: Pioneer fitting couplers Allis 6080
    Posted: 03 Apr 2022 at 9:57pm
Hello All!
All major oil leaks fixed, and the tractor is ready for service. Thanks everybody!!!
What size are the pioneer fittings on the rear hydraulics? I have a Century 6080 I have been running a post pounder on. The hydraulic is an iso fitting. Anyway to easily get a coupler that will work?
Thanks again!
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2022 at 11:29pm
That probably has Allis couplers...
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 5:58am
The couplers on the 6080 should take any iso coupler.  Such as the Pioneer 8010 series.  8010-4 is the pipe thread version, 8010-15 is 3/4 oring, etc.
ryan
Myrastomean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Myrastomean Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2024 at 6:59am
I’ve seen some oddball sizes depending on the setup. When I needed to hook up my log splitter to my tractor, I ran into a similar issue with mismatched couplers. After way too much trial and error, I ended up deciding to buy quick couplers from Northern Hydraulics. They had ISO-compatible options that worked perfectly, and the whole process of swapping attachments got way easier.If you’re running a post pounder, you’ll definitely appreciate having a solid coupler setup. Double-check the size, and once you’ve got that nailed down, the swap should be a breeze.
Edited by Myrastomean - 20 Dec 2024 at 12:20pm
