Pinion shaft help!
Jcashsalt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcashsalt Quote  Post ReplyReply Direct Link To This Post Topic: Pinion shaft help!
    Posted: 13 Feb 2017 at 9:15pm
Hello everyone I'm in need of some help. I've got a 42 b. I believe it's the pinion shaft the one that has the 14tooth gear that runs the bull gear. The bull gear has a chunk of tooth missing and also messed up that top smaller 14 tooth gear, problem is the gear looks like it's built into the shaft. Has anyone replaces one and if so where can I find one? Thank you guys in advance. -John
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 9:30pm
Are you close to Tony Carbaugh ? I bet he has a used final drive. I bet that would be as good as finding parts to repair yours. his # is 503-767-3660
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcashsalt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 11:04pm
Ok thank you so that gear is built in with the shaft?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:21am
I think so
Wink
I am a Russian Bot
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:58am
Go to this site and log on as Guest User to View Books:
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
Insert "B" under Search By Model and pull down AGCO Allis beside it.  You can then see parts explosions to confirm your thinking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 7:43pm
Yes the gear is part of the shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcashsalt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 9:45pm
Thanks for the help guys Tony's tractors is helping me out great guy
