Pics of CA with 3pt hitch |
BV
Joined: 12 Sep 2009 Location: Bono Arkansas Points: 492 |
Topic: Pics of CA with 3pt hitchPosted: 04 Jun 2017 at 8:08pm |
I have a CA pin hitch I would like to put a 3 pt on, can someone post pics of their tractor with the hitch please?
DSpears N IL
Silver Level Access
Joined: 11 Sep 2009 Location: Rockford,Ill Points: 418 |
Posted: 04 Jun 2017 at 8:51pm |
![]() ![]() Hi BVI have a CA with the Snap couple system. It may give you some ideas to work with for your pin hitch setup. I designed and had built the first bracket and bought the arms & draw-bar to fit. the lift arm brackets are early AC components. I also had to make a top-link bracket for the lift arm shaft. The 2nd hitch is from an AC plow hitch that I had 3-point eyes welded onto the ends for the draw-bar. I also use this hitch for using a 4 foot tiller. Hope that this will inspire you to design your own system! DeWayne Edited by DSpears N IL - 04 Jun 2017 at 8:55pm |
CTuckerNWIL
Posted: 04 Jun 2017 at 8:55pm |
I'd like to see that myself. Since the pin hitch set up uses the lift arms for the drawbar bail, you can't have a drawbar on it with a 3 point hitch.
It might be easiest to go with a "wishbone" style 3 point . OK tractor has one that will pin up to the early CA. Notice the insert in the lower right corner. http://oktractor.com/zen/index.php?main_page=popup_image&pID=204 Edited by CTuckerNWIL - 04 Jun 2017 at 8:56pm |
BV
Posted: 05 Jun 2017 at 3:05pm |
Thank you very much both of these setups look good to me, thanks again
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 05 Jun 2017 at 4:14pm |
DeWayne's got all the neat toys. I'm jealous!
DSpears N IL
Silver Level Access
Posted: 05 Jun 2017 at 7:28pm |
Brian has the new garage for his toys!!!!
I need More Space!!!!! DeWayne ![]() |
