picker shields
 Rating: Topic Rating: 2 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: picker shields
    Posted: 15 Aug 2012 at 1:15am
In thinking about my future 262-WD45 project, I was wondering if they ever made extended picker shields for the longer hood on the 45D? maybe first I should ask, was there a mounted picker that fit the 45D? I would like to have side shields for this project if I ever got around to it, maybe I'll have to make my own.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 1:37am
A year or two back, I saw a 45 diesel with a mounted picker at Sumerix Equipment in Lachine, MI. I can't remember if it had shields on it, but you could call them and ask Ivan. He posts on here as auctioneer.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 10:11am
Yep. they did make the model 33 picker, adaptable to the WD45D.
Side shields were extended by a hole mesh screen on both sides.
Galatians 5:22-24
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 10:28pm
mounting the picker itself shouldn't matter as the frame is the same?  If you could find a picture in a manual you could make one.  It would get a lot of attention at a show!
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 11:22pm
would be expensive, but the best result would probably be had by buying two sets of shields and cutting them unevenly so I have 4 longer halves and welding the longer halves together, similar to extending a hood
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 7:10am
Bill, if you want, I could take pictures from my picker manual. If that helps.
Galatians 5:22-24
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 7:44am
Did they make picker shields for the D17 diesel? If so, does anybody have any pics?
Thanks, Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 7:45am
Not sure, I think I have that manual at home too, will check tonight Bryan.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 8:18pm
As promised, here ya go Bill and Bryan....
The WD45D, note the difference between the LH and RH side shields...
This is a comparison between the standard and the diesel (bottom shields) versions..
This is the D-17 version side shields for the 170 picker
Galatians 5:22-24
