Pic of D19 cam followers
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: Pic of D19 cam followers
    Posted: 18 Mar 2011 at 3:11pm
after removing the hyd pump and taking the followers off the pump. The first two were busted up and the last 2 were ok. As I said the wierd part is cam lobes 2 and 3 are scarred up...the first and fourth are fine even though the first 2 followers were bad. Baffles me but the bottom line is she's a hurtin unit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 3:11pm
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 3:53pm
See yer previous post, sounds like Bill can fix you up with followers and maybe a shaft.  Yea its fugly.  You should also take the pump apart, clean it up and replace the orings.  Good luck.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 4:41pm
heres a pic of the ones from my d17 my cam wasnt near chewed up as yours was I replaced the followers and the hyd now work ok little slow tho
