Phrases often heard while looking to buy a tractor
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: Phrases often heard while looking to buy a tractor
    Posted: 23 Jul 2023 at 9:47am
"needs a starter"......this is a common one, and usually means the engine is locked up.      "ran when parked".........yeah, right, so did the Titanic.                                                     "needs a tune-up"..........almost assuredly has a burnt valve.                                         "don't know much about it, but........"    this one speaks for itself.                                     Tongue
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2023 at 10:51am
just needs air in one  tire  = tire is rotted away and the other rim is rusted out
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2023 at 11:25am
“Should be an easy fix” … Then why didn’t You?
Edited by wade89 - 23 Jul 2023 at 11:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2023 at 12:27pm
"was well maintained.. up until a couple years ago"................  setting in a field with a 15 ft tree growing up thru the frame.." been out here a year or two"..
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 12:07am
    It's amazing how that leaking hydraulic fluid can fertilize trees.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 12:10am
  My Massey 65 was like that when I bought it....add air to the tire and watch the water squirt out from all the holes in the rim.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 7:53am
"With a little work...."
Usually said by someone wanting full retail for a project.
"Good as new!"
Some jockey detailing just how a repair was done
on the pile he's trying to unload on you.
Learning AC...slowly
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 8:01am
Always good is ‘Recently Overhauled’ as has a fresh coat of Dupont. Engine smokes and or misses or leaks all over.
exSW View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 8:03am
Or they rolled in new rods and mains and it makes good oil pressure for about the first 20 minutes.
Edited by exSW - 24 Jul 2023 at 8:04am
Post Options Post Options   Thanks (1) Thanks(1)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 8:30am
    I've heard that one called 'the Rustoleum Rebuild".
Post Options Post Options   Thanks (1) Thanks(1)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 8:38am
Oh, and let's not forget; "Has rebuilt injector pump and new injectors-just need bled" as you watch raw diesel fuel dripping out of the exhaust when cranking it....
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 9:06am
Rare - over 100k made
Highly collectible - just can't find elusive buyer too pay for the "collectability" for some reason.
New radiator, water pump, and thermostat - engine block is full of crud, so it still overheats
Been in the family since we were kids - buyer must pay seller's sentimental value fee on top of tractor value
Not sure why won't run, but likely easy fix - the engine is totally worn out.
pinball View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2023 at 9:14am
well folks i agree but sometimes it is the truth. the world may be screwed up but there's a lot of good honest people out there.  it's just up to the buyer to figure that out.  i find women are the biggest liars.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2023 at 4:33pm
Tires hold air.
Actually all tires hold air, it's the ones that hold air under pressure that are impressive.
Always sheded.
Covered in bird crap.
Many offers
But nobody wants the whole thing
Edited by Dave Richards (WV) - 27 Jul 2023 at 4:35pm
