Pertronix Coil for a CA
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Pertronix Coil for a CA
    Posted: 28 Apr 2020 at 8:40pm
Which pertronix flamethrower coil should I use for one of these modules a 1.5 or 3 ohmes? TIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 4:53am
IIRR, its a 3 ohm...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 5:30am
I'd assume 1.5 ohm is for a 6 volt battery , 3 ohm for a 12 volt battery, Those numbers give 4 amps of current to the coils. ( 6/1.5), (12/4).
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 6:19am
Depends greatly on which system yer' runnin'. If its still 6V use the 6V coil. If its a 12V conversion, 4 cylinder's on 12V's need 2.7-3.3 ohms of resistance in the ignition circuit, so the 3.0 ohm coil is the ticket. The 1.5 ohm coils work fine with 6 & 8 cylinder engines. We have the 3.0 ohm coils in stock if interested.....
Steve@B&B
bb-customcircuits.com
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 12:49pm
Please correct me, if I'm wrong but, a few months ago, I was reading about the Pertronix conversion and the coil needed.
As I remember, the conversion needed the 1.5 ohm coil, used with a resistor if 12V.
I bought a 3 ohm Pertronix coil to use with a 12V, point system (w/o resistor). If I try to use a 1.5 ohm coil, with direct 12V, it burns the points, in a very short time.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 4:22pm
old school rule..for the Kettering ignition system( grade 9 autoshop..)
points 'like' 4 amps running through them.. supplies enough energy to a coil, but won't burn the points.
so 6 V / 1.5 ohms = 4 amps...points are happy.
12 V / 1.5 ohms = 8 amps.... burnt points, ouch !
EI system still have to supply power to the coil, but you need to read what the coil wants and MATCH it to the EI system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 4:47pm
I have no clue what you read, but the 1.5 Ohm coil works great with 6 & 8 cylinder engines. As I said, when running a 4 cylinder on 12V's you need 2.7-3.3 ohms in the ignition circuit for the engine to run correctly and to keep the points in service for a long time.
Steve@B&B
