parts
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Topic: parts
    Posted: 31 Dec 2022 at 11:47am
looking for a place to get cylinder bars for an E gleaner combine as mine are pretty worn. i'm also looking for the shaft lengths for the drive shaft on the cornhead for the 60/66 combine since i will have to make one for mine . thanks in advance.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 5:23pm
Cylinder bars for E-E3-K-K2 are all the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 5:38pm
DrAllis where do you get them from?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 8:23pm
AGCO has them at $330 apiece. If yours aren't worn paper thin but the top is worn down,you can send them to Trimpe in Seymour IN for welding up. May have a set ready for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 8:46pm
I just looked in a Shoup catalog and they don't have them. I'd guess the $330 price is a pair, but still $1320 for a full set of 8 bars. Trimpe bars are great for corn and soybeans. Won't work well for small grains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 8:51pm
What are the part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 1:02am
AGCO just gives Pt #,price and says 8 required. To me that means X apiece. A dealer can find out.
Trimpe usually cuts out every other rib to make wide spaced bars. No reason they couldn't  build up all ribs on std bar for small grains.
Edited by SteveM C/IL - 01 Jan 2023 at 1:05am
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 9:50am
That price is per pair
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 1:48pm
Thanks for the clarification Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 3:21pm
They were sold in pairs for balance. Remove one old cyl bar and replace with new. Turn the cylinder 180 degrees and remove/replace the next one to keep cylinder balanced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 9:03pm
I always marked mine on the backside with letter stamps to keep the pairs together. Used to run just 4 in the A2 in beans. Was a HOGG and would eat all the green weeds you could feed it...had to keep an eye on the chopper belt after a big bite of that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 9:07pm
Thanks for all the information guys. Now I have someplace to start.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 2:25pm
How bad are they worn? On both my "E" and "K" (years ago), I took them off and turned them 1/2 turn and had a new wear surface!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 3:15pm
St. Johns Welding & Mfg Inc.
St. Johns Kansas
Fax 620-549-3262
TollFree 800-549-3289Welding & Mfg Inc.
These people have been in business a very long time.  They do an excellent job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 4:10pm
I can shave with them
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 4:12pm
The price is each Ryan. The cost for a set of 8 bars is a little over 2700.
