Parts to put a 426 in a 200?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Parts to put a 426 in a 200?
    Posted: 24 Dec 2021 at 8:17am
Anyone know of anyone making the engine plate/ whatever needed  etc to put a 426 in front of a 200 Power Director ?
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2021 at 9:54am
  Video on YouTub ,guy started putting one in D-19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 8:59am
Ah gottcha- Ill check it out , thanks
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 11:08am
I used the 426 plate from a 7580 and relocated starter to 301 position. Grind some off the block(3500) to make starter fit. Relocate oil filters and custom flywheel to use 301 ring gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 11:46am
Gottcha, thanks- was thinking about using the 426 engine plate redrilling holes for the 200- and using a 301 flywheel and clutch - sounds easy !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 4:02pm
Take pictures as you go along and share with us !!!
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 6:58pm
I to have always wanted to do a 426 in a 200. Thought it would be a cool sleeper farm stock puller. Please share pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 9:21pm
[IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2021 at 9:32pm
My centering device to lay both back plates on
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2021 at 5:38pm
Dang Goomer you got it going on there ! Nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2021 at 6:17pm
On a similar note: Does anyone have a progress report on the fellow putting a 426 in the D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2021 at 1:47pm
This has always on my project list - as I have a 200 from the PD back, Id like to tube frame it and put 7000 series metal on it - see what happens
